Community
cancel
Showing results for
Search instead for
Did you mean:
SSisj
Intel Aero Drone does not stay on
Jump to solution
I have had issues with powering up my drone. Due to a damaged power distribution board, I replaced it with a new one while also having a new Intel compute board being installed on the drone. Although the drone starts up now, I have run into the issue that it does not stay on for longer than around 10 seconds.
Thank you,
Steven Sisjayawan
Tags (1)
Community Manager
Hi stevens,
Thank you for your interest in the Intel Aero drone.
Please try flashing the compute board OS, FPGA, Bios and Flight controller. Make sure you are using the correct FPGA jam file (aero-rtf.jam). You should be able update the board outside of the drone.
https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation
Alexandra
Community Manager
Hi stevens,
Alexandra
Community Manager
Hi stevens,
Could you please let us know if you require further assistance on this matter?
Thank you,
Eliza
SSisj
Hi Eliza,
Thank you, I am trying to flash all the different components.
StevenS
Community Manager
Hello steven,
Thank you for the information.
Please let us know after you have finished this process.
Kind regards,
Eliza
SSisj
Hi Eliza,
I have managed to flash the compute board OS, FPGA, Bios and flight controller. However, when I try to install Ubuntu 16.04, the monitor just goes to sleep while the drone stays. How long does the ubuntu installation usually take, I have waited for up to 30 minutes.
Thank you,
Steven S
Community Manager
Hello stevens,
The installation should not exceed 30 minutes. I would recommend to use another USB stick and a fresh downloaded Ubuntu 16.04 image.
Thank you,
Eliza
Community Manager
Hi stevens,
Did it solve your issue?
Do you need further help?
Alexandra
