Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Intel Aero RTF do NOT see USB periferals
CBell1
New Contributor II
I just started my Intel Aero RTF Drone.
Versions
BIOS Aero-01.00.11 10/24/2016
Yocto 4.3
I have connected Keyboard & Mouse to the Drone using an external USB 3.0 Hub and Video by Mini USB to HDMI adapter to the dedicated port.
All following the instruction.
The Aero RTF do not detect the Keyboard and Mouse.
Video output by HDMI is ok, I can see the boot process but I cannot interact.
The SSH works, ok.
I tried to connect only an USB Key to the USB 3.0 port to the Drone but again it do not see the External drive, below the Fdisk -l result:
Device Start End Sectors Size Type/dev/mmcblk0p1 20485939157344 28M EFI System/dev/mmcblk0p259392 58019839 57960448 27.7G Linux filesystem
/dev/mmcblk0p3 58019840 61069311 3049472 1.5G Linux swap
I connected and removed the external USB Key with the same result below (no additional device is available!
root@intel-aero:/# ls /dev/ | grep sd
ptysd
sda
sda1
sda2
ttysd
Could the USB be disabled by factory?
Please, do you have some suggestions to solve this issue?
Thank you
mkoi
SOLVED: Eliza please make clear note of this for future customers.
You must use a specific micro B USB 3.0 OTG adapter. Some micro B USB 3.0 cables do not have the correct internal jumper wire.
HERE IS WHAT YOU NEED:
https://www.amazon.com/gp/product/B00KDY8R6C/ref=od_aui_detailpages00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00KDY8R6C/ref=od_aui_detailpages00?ie=UTF8&psc=1
Here is the PINOUT for the MICRO B USB 3.0 connector:
You must have OTG cable (pin jumpered):
DO NOT USE a micro B USB 3.0 hard drive cable. For example, from a LACIE external micro B USB 3.0 hard driver. It will fail, and make your OS upgrade impossible. If you see a USB HUB LED flashing in this sequence, then you know you have the wrong cable:
The USB HUB LED will:
- LED will stay on for 5 seconds after powering on RTF drone (NO USB keys work)
- LED will turn off for 9 seconds while BIOS loading (showing Intel logo)
- LED will stay on for 8 seconds at GRUB menu, and initial boot loading (NO USB keys work)
- LED will turn off and stay off. (No keyboard, USB drivers, etc. will work)
THIS CLOSED. Thx Eliza.
Community Manager
Hello Cosma,
Thank you for your interest in the Intel Aero Ready to Fly drone.
Could you please let me know if you have tested the USB Hub on another device?
If it works, I would recommend to flash the latest Yocto image on your drone. Link to download here: https://downloadcenter.intel.com/download/27833/Intel-Aero-Platform-for-UAVs-Installation-Files%3Fv%... https://downloadcenter.intel.com/download/27833/Intel-Aero-Platform-for-UAVs-Installation-Files?v=t and follow the instructions from here: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup%23flashing-intel-aero-linux-dist... https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup# flashing-intel-aero-linux-distribution
Looking forward to your reply!
Thank you,
Eliza
CBell1
New Contributor II
Hi Eliza,
I tried two 3.0 USB hubs and I direct attached a USB key using a USB 3.0 adapte with not results.
The only mode I have to communicate wi the Drone is SSH.
So, to update the OS and BIOS I can only try to transget data using Putty and execute them from the Drone's OS comman line.
Please, do you have any suggestion?
or do you have some instructions to update the Drone by SSH?
Thank you
Community Manager
Hello Cosma,
Thank you for the information.
It is possible that your USB access is disabled in BIOS.
You can access the BIOS to revert that back using the UART on the power connector, but first you will need to program the FPGA to disconnect that UART from the flight controller or disconnect it (not recommended if you never disassembled it). I came across this thread on GitHub that might help you. Link here: https://github.com/intel-aero/meta-intel-aero/issues/363
Thank you in advance,
Eliza
CBell1
New Contributor II
Hi Eliza,
So, if I well understand, I have to:
-1 execute the script:
https://github.com/intel-aero/meta-intel-aero/blob/master/recipes-support/jam-stapl/jam-stapl/aero-c... aero/blob/master/recipes-support/jam-stapl/jam-stapl/aero-compute-board.jam
-2 access the BIOS to revert that back using the UART on the power connector.
Is it right?
Please, do you have more details about the point 2?
Thank you
CBell1
New Contributor II
Hi Eliza,
I have anothere question:
I have transferred the last bios version (.rpm file) to the Drone by SSH.
If I execute the Bios upgrade, can this operation reset the Bios enabling again the USB ports?
thank you
Community Manager
Hello Cosma,
Indeed, this should solve your issue.
Please keep the micro HDMI to HDMI cable connected to the monitor and watch the progress. You can use the commands described here: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup# flashing-the-bios
Could you please do that and let me know the outcome?
Eliza
CBell1
New Contributor II
Hi Eliza,
I successfully saved the file aero-bios-01.00.16-r1.corei7_64.rpm in the home/root/sdcard using SSH transfer file.
I have executed the command:
rpm -ivh aero-bios-01.00.16-r1.corei7_64.rpm that returned the following output:
warning: package aero-bios-01.00.16-r1.corei7_64 is intended for a corei7_64-unknown-linux platform
Please, do you have a suggestion?
Or do I have to transfer the ISO (1.6GB) within the Aero Drone and execute that as the last option?
Thank you
CBell1
New Contributor II
Hi Eliza,
below the output to the command aero-get-version.py via SSH:
root@intel-aero:/# aero-get-version.py
-sh: aero-get-version.py: command not found
root@intel-aero:/# python aero-get-version.py
python: can't open file 'aero-get-version.py': [Errno 2] No such file or directory
I executed the following commands to know the OS version:
root@intel-aero:/# uname -r
root@intel-aero:/# 4.4.3-yocto-standard
root@intel-aero:/# rpm -qa | grep openssl
openssl-conf-1.0.2h-r0.core2_64
openssl-1.0.2h-r0.core2_64
openssl-dev-1.0.2h-r0.core2_64
Below, you can find the image of my Intel Aero RTF Drone (formally Intel Aero Platform for UAVs)
It's new! It's really particular that it was shipped without test it with USB disabled or damaged!
Or it seems, the Drone was already used.
Questions, please:
1- can you let me know the path where I have to execute the aero-get-version.py command?
2- It seems the Drone has a port for micro SSD card (image 3), could I use it to upload the ISO?
3- Where I can find the existing Bios RPM package that I have to remove before install the news one following the instruction?
4- Can you send me more details about the procedure to revert back the BIOS using the UART on the Power Connector?
Otherwise, Please, let me know your suggestions to reset the Bios via Hardware instead software.
Many thanks for your commitment!
Community Manager
Hello Cosma,
Thank you very much for everything.
I will take your questions one by one.
1. It should work directly from: root@intel-aero:/# or any other folder - but if it doesn't open there is no issue.
2. No please, this SSD card is used for stocking the flight logs
3. Try please with rpm -ev aero-bios-01.00.11-r1.corei7_64 instead of the 01.00.13. It should be on root@intel-aero:/#
Please run the below commands: rpm -ev aero-bios-01.00.11-r1.corei7_64
(navigate to home/root/sdcard) rpm -i aero-bios-01.00.16-r1.corei7_64.rpm
aero-bios-update
In case you will receive a similar error message as before, I would recommend to do try the below commands from the folder where you have stored aero-bios-01.00.16-r1.corei7_64.rpm - home/root/sdcard (Found them here: https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation# bios)
rpm2cpio aero-bios-01.00.16-r1.corei7_64.rpm | cpio -idmv
sudo mv BIOSUPDATE.fv /boot
sudo reboot
4. If you have successfully send the .jam file to Aero RTF ( https://github.com/intel-aero/meta-intel-aero/blob/master/recipes-support/jam-stapl/jam-stapl/aero-c...) execute :
cd /etc/fpga/
jam -aprogram aero-compute-board.jam
Please let me know the outcome after that.
Looking forward to hear from you!
Thank you very much in advance,
Eliza
CBell1
New Contributor II
Hello Eliza,
I executed the mentioned steps, below the results:
point 3:
no results as in my previous experiences:
output:
warning: package aero-bios-01.00.11-r1.corei7_64 is intended for a corei7_64-unknown-linux platform
I tried also other versions 01.00.10 or 01.00.12 and 01.00.13 -> same error
root@intel-aero:~/sdcard# rpm2cpio aero-bios-01.00.16-r1.corei7_64.rpm
-sh: rpm2cpio: command not found
Point 4 (.jam file):
within /etc there was not the folder "fpga"
Why? Where could be the original fpga folder?
Anyway, to proceed, I created it within /etc and I executed the command with a result (finally!)
root@intel-aero:/etc/fpga# jam -aprogram aero-compute-board.jam
Jam STAPL Player Version 2.5 (20040526)
Copyright (C) 1997-2004 Altera Corporation
Device # 1 IDCODE is 031820DD
full-chip erasing Max 10 FPGA device(s) ...
programming Max 10 FPGA CFM0 block at sector 4 ...
programming Max 10 FPGA CFM0 block at sector 5 ...
programming Max 10 FPGA UFM block at sector 1 ...
programming Max 10 FPGA UFM block at sector 2 ...
programming Max 10 FPGA UFM block at sector 3 ...
verifying Max 10 FPGA CFM0 block at sector 4 ...
verifying Max 10 FPGA CFM0 block at sector 5 ...
verifying Max 10 FPGA UFM block at sector 1 ...
verifying Max 10 FPGA UFM block at sector 2 ...
verifying Max 10 FPGA UFM block at sector 3 ...
programming Max 10 FPGA DSM block ...
DONE
Exit code = 0... Success
Please, let me know the next step with some details to reset the Bios.
Thank you again
Community Manager
Hello Cosma,
This is great news that you got the .jam file!
In order to update the BIOS and make sure that the latest version is updated and working, the error message from the rpm commands needs to be resolved. Please run in home/root/sdcard the below commands: sudo alien -i package_file.rpmsudo alien package_file.rpmsudo dpkg -i package_file.deb I would recommend to check out this thread: https://communities.intel.com/thread/124337 https://communities.intel.com/thread/124337 as it contains more information on this topic.
Please let me know the outcome!
Eliza
CBell1
New Contributor II
Hello Eliza,
the alien commands are not found.
it seems this procedure is for Ubuntu OS, on my Drone is running Yocto 4.4.3
please, can you send me the procedure to access the Bios to revert that back using UART on the power connector?
it was what you have previously suggested to reset the Bios to factory.
Many thanks
CBell1
New Contributor II
Hi Eliza,
there is a great news, I updated the Bios to 01.00.16-r1
Unfortunately, the USB still disabled (otherwise the USB port hardware is damaged) and I cannot use Keyboard & Mouse.
To update the Bios, I have applied the following procedure:
I decided to use a rpm2cpio packaged from:
https://github.com/ruda/rpm2cpio
On the Drone via SSH:
root@intel-aero:~/sdcard/rpm2cpio-master# python rpm2cpio.py < aero-bios-01.00.16-r1.corei7_64.rpm | cpio -idmv
./etc
./etc/bios
./etc/bios/BIOSUPDATE.fv
16585 blocks
root@intel-aero:~/sdcard/rpm2cpio-master# ls
LICENSE README etc rpm2cpio.py
Makefile aero-bios-01.00.16-r1.corei7_64.rpm rpm2cpio.1
root@intel-aero:~/sdcard/rpm2cpio-master/etc/bios# sudo mv BIOSUPDATE.fv /boot
root@intel-aero:/boot# ls
BIOSUPDATE.fv EFI vmlinuz
root@intel-aero:/boot# sudo reboot
See the image below:
Unfortunately, the USB still disabled and I cannot use the keyboard & Mouse with an external powered USB hub, image below:
The LEDs of the Intel Aero RTF Drone are green.
Please, do you have any suggestions to enable the USB?
Thank you
CBell1
New Contributor II
Hi Eliza,
additional informations:
1)
from grep USB command with external USB hub connected with Keyboard and Mouse + Video HDMI connected:
root@intel-aero:/var/log# dmesg | grep USB
[ 0.315091] ACPI: Power Resource [USBC] (on)
[ 0.417469] ACPI: bus type USB registered
[ 1.762959] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.762999] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.763030] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.763356] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.765449] hub 1-0:1.0: USB hub found
[ 1.767410] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.767872] hub 2-0:1.0: USB hub found
[ 1.769699] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.769853] usbserial: USB Serial support registered for generic
[ 1.769889] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.769960] usbserial: USB Serial support registered for pl2303
[ 2.883939] usbhid: USB HID core driver
[ 2.956106] usb 2-4: new SuperSpeed USB device number 2 using xhci_hcd
[ 3.353552] pmic_ccsm wcove_ccsm: SOC-Internal-USBPHY used
[ 3.365096] pmic_ccsm wcove_ccsm: USB VBUS Detected. Notifying OTG driver
[ 3.900039] USB Video Class driver (1.1.1)
[ 3.970353] intel-cht-otg intel-cht-otg.0: USB_EVENT_VBUS vbus valid
[ 5.937697] usb 2-4: USB disconnect, device number 2
[ 6.366005] pmic_ccsm wcove_ccsm: USB VBUS Removed. Notifying OTG driver
[ 6.367621] intel-cht-otg intel-cht-otg.0: USB_EVENT_NONE cable disconnected
[ 6.440038] usb 2-4: new SuperSpeed USB device number 3 using xhci_hcd
2)
In /etc folder there are the following files:
aero_RTF_kit_fpga.jam
aero_compute_board_only_fpga.jam
Could they be helpful?
3)
in the OS image within the Drone, it seems there are not other aero-... files excepted the .jam and Bios rpm files I have sent by SSH.
In the OS image there was NOT the folder etc/fpga . I have created that manually.
In my opinion this drone was not delivered with the right configuration and test.
Please, let me know you opinion and suggestions to solve the USB issue and to upgrade the OS to the last version.
Many thanks for your support.
Best Regards
Community Manager
Hello Cosma,
Thank you very much for the details!
We are currently investigating it and we will try to provide you a resolution as soon as possible.
Thank you very much!
Eliza
Community Manager
Hello Cosma,
It's possible the issue is due to the USB adapter used between the Intel Aero RTF Drone and the USB Hub. If it is possible, could you please try a different adapter?
Thank you very much and I am looking forward to hear from you!
Eliza
CBell1
New Contributor II
Hello Eliza,
I tried 2x USB 3.0 cables and 1x USB 2.0 cable. I tried 2x USB hub with external power. No results, same issue.
please, can you send me the procedure to update the OS using WiFi, remote installation?
Thank you
Community Manager
Hello Cosma,
Unfortunately, the only was to flash the OS is via the USB Port.
Do you think it is possible to send us a picture of the USB connector? Do you see any damage on the port? A picture of the USB port connection to the PCB board and soldering connections would be great.
Also, can you please mention when did you purchase the drone? Did the USB port worked in the past?
Thank you very much,
Eliza
CBell1
New Contributor II
Hello Eliza,
actually, I don't have the Drone with me, I'll check again the USB connector on Friday or during the weekend and I'll keep you informed.
The Drone is new! Directly Intel provided me the Drone as Award by Dell (I'm a Dell employee)!
Additional information:
I have tried also to calibrate the Drone using QGroundControl by WiFi without success, the application cannot find the Drone.
I have tried using Ubuntu and Windows disabling the firewall, ping was ok but the QGC do NOT identify the drone.
A quick resume of the status of the Intel Aero RTF Drone I have received as New Drone:
1- the USB do not work
2- the OS doesn't have the files "aero-..." mentioned in the instruction,
3- the OS doesn't have the directory "etc/fpga" (I have create it manually),
4- the QGC application doesn't connect to Drone.
Do I have to request a replacemen?
Thank you
CBell1
New Contributor II
Hello Eliza,
the physical USB port on the Drone seems ok (images attached).
I tried again all USB connectors and Hubs with NOT results.
A quick resume of the status of the Intel Aero RTF Drone I have received as New Drone directly from Intel:
1- the USB does NOT work
2- the OS doesn't have the files "aero-..." mentioned in the instructions,
Do you have some suggestion?
Is it necessary to replace the Drone?
Thank you
Cosma
