Community
cancel
Showing results for
Search instead for
Did you mean:
UGoya
Intel AeroFC Firmware version = unknown
Jump to solution
I am getting ready to install Ubuntu 16.04 on the Intel Aero RTF. The instructions first mention to update the BIOS, FPGA and FC. I followed all the instructions here
https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup
I downloaded the latest .iso and flashed the drone with it.
Then updated the BIOS and the FPGA. Then updated the FC.
Then when I ran aero-get-version.py I see this
root@intel-aero:~# aero-get-version.py
BIOS_VERSION = Aero-01.00.16
OS_VERSION = Poky Aero (Intel Aero Linux Distro) 1.6.2 (pyro)"
AIRMAP_VERSION = 1.8
FPGA_VERSION = 0xc0
AeroFC firmware version = unknown
I also tried to install ubuntu after it, but it is not getting installed.
Please help.
Thanks in advance
Eliza_D_Intel
Hello Utkarsh, Let's continue the conversation about the dependencies issue on your other thread: https://forums.intel.com/s/question/0D50P00004FwlYL/wget-qo-httpsdownload01orgaerodebintelaerodebkey... Thank you and best regards, Eliza
Eliza_D_Intel
Hello UGoya, Thank you for your interest in the Intel Aero Ready to Fly drone. Could you please let us know what is the outcome of the command lines from: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup#flashing-the-flight-controller-r... ? Thank you and best regards, Eliza
UGoya
IMG_20190305_101724.jpgHello ELiza
I have tried the command which you provided in your link,
But still it is saying the firmware version = unknown
I am attaching the screenshot of the execution of the command which is given in the link.
And why I am not bale to install the Ubuntu on the Intel Aero RTF.
Please help
Thanks and Regards
Utkarsh
Eliza_D_Intel
Hello UGoya, From the link you have provided, it seems that the firmware was indeed updated successfully. It should not be a problem installing Ubuntu. Can you let me know what are the issues you are encountering? Thank you and best regards, Eliza
UGoya
Hello Eliza
I have successfully installed the ubuntu on my Intel Aero RTF
But, Thanks for your help
Utkarsh
Eliza_D_Intel
Hello UGoya, Great news! Can you please let us know if the firmware version is now displayed if you run: sudo aero-get-version.py ? Thank you, Eliza
UGoya
Hello Eliza
Thanks for follow up
Actually I have installed the Ubuntu, now I have to install the dependencies, but this command:
wget -qO - https://download.01.org/aero/deb/intel-aero-deb.key | sudo apt-key add -
is not working .
Actually I think the link in this command is not more active.
Can you please check it and let me know.
Thanks and Regards
Utkarsh
Eliza_D_Intel
UGoya
Hello Eliza
Yes sure.
I apologize for asking different question on different topic.
Utkarsh
Eliza_D_Intel
Hello Utkarsh, Not a problem! Thank you very much for understanding! Thank you and best regards, Eliza
