So after reciving my intel aero board, i am having trouble tyring to connect the board to a lipo battery in order to get this board to intergrate with the drone. With the charger from the aero board, there is a 3 pin connecter that I am not sure what it is used for, but there is also a 3pin female adapter that fits with these pins to connect to the aero baord on the dji naza v2 power modicaficaiton unit. After connencting, I am still getting no power to the board as it is not turing on. Could someone let me know if I am making a mistake on how to connect the board to the battrey. I will also include picutres.
Hi AymanSaleh1232,
I would love to help you with this. Let me investigate more about it, and I'll let you know when I have updates.
Have a nice weekend.
-Leonardo
Hi AymanSaleh1232,
I just want to let you know that we are still working on the documentation that includes powering the Aero Platform from a Li-Po battery.
About the 3 pin connector on the power supply, it is a UART port, see this for additional information.
https://github.com/intel-aero/meta-intel-aero/wiki/Quickstart-Guide# via-uarts1
We hope to have the information available soon.
We appreciate your patience.
-Leonardo
Hi AymanSaleh1232,
Check this document: https://communities.intel.com/docs/DOC-111394 https://communities.intel.com/docs/DOC-111394, it would be helpful for you.
Have a nice day.
-Leonardo
Hi AymanSaleh1232,
Did you check the document? Was it helpful?
-Leonardo
I am a little confused when the directions say
Modify the supplied power cable by removing the barrel connector and connecting +VIN and GND per the pinout described in Table 1.
What is the barrel connector and what do I connect the +VIN and GND too?
Hi As2399,
Look at the photo:
The part inside the circle is the barrel connector that you have to removed, then you need to connect those cables (+Vin, Ground) to the pins of the table 1 of the document.
Have a nice day.
-Leonardo
