Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
Intel aero // Mavros - Clock skew detected
CSill
Hi all,
when establishing a mavros connection between my Laptop (Ubuntu 16.04 LTS , running ros), and the Intel Aero RTF via UDP
$ roslaunch mavros px4.launch fcu_url:="udp://0.0.0.0:14550@192.168.0.73:14556" (IP of drone in local network)
the console yields the following
[ INFO] [1505308969.287351579]: MAVROS started. MY ID 1.240, TARGET ID 1.1
[ WARN] [1505308969.372640545]: TM: Clock skew detected (-1505308694.417684555 s). Hard syncing clocks.
[ INFO] [1505308969.393820707]: IMU: High resolution IMU detected!
[ INFO] [1505308969.393991552]: IMU: Attitude quaternion IMU detected!
[ INFO] [1505308969.727654561]: CON: Got HEARTBEAT, connected. FCU: PX4 Autopilot
[ INFO] [1505308970.051755980]: IMU: High resolution IMU detected!
[ INFO] [1505308970.052007967]: IMU: Attitude quaternion IMU detected!
[ INFO] [1505308970.740422861]: VER: 1.1: Capabilities 0x00000000000024ef
[ INFO] [1505308970.740548486]: VER: 1.1: Flight software: 01060500 (000000000181F900)
[ INFO] [1505308970.740654226]: VER: 1.1: Middleware software: 01060500 (000000000181F900)
[ INFO] [1505308970.740712155]: VER: 1.1: OS software: 000000c0 (0000000000000000)
[ INFO] [1505308970.740770259]: VER: 1.1: Board hardware: 0000a4a7
[ INFO] [1505308970.740831751]: VER: 1.1: VID/PID: 0525:a4a7
[ INFO] [1505308970.740884032]: VER: 1.1: UID: 3335511839343335
[ WARN] [1505308970.740974275]: CMD: Unexpected command 520, result 0
[ WARN] [1505308979.375366479]: TM: Clock skew detected (7718063342.435769081 s). Hard syncing clocks.
[ INFO] [1505308979.728118434]: HP: requesting home position
[ INFO] [1505308984.735264665]: WP: mission received
[ WARN] [1505308989.471157623]: TM: Clock skew detected (-7718063342.437295914 s). Hard syncing clocks.
[ INFO] [1505308989.728430551]: HP: requesting home position
[ WARN] [1505308999.473095008]: TM: Clock skew detected (7718063342.437585831 s). Hard syncing clocks.
[ INFO] [1505308999.728594636]: HP: requesting home position
Executing the mavros topic "time_reference"
$ rostopic echo /mavros/time_reference
yields the following:
header:
seq: 201
stamp:
secs: 1505309160
nsecs: 267349839
frame_id: ''
time_ref:
secs: 1505309160
nsecs: 265019000
source: fcu
header:
seq: 202
stamp:
secs: 1505309161
nsecs: 304928103
frame_id: ''
time_ref:
secs: 1505309161
nsecs: 265189000
source: fcu
now, my question: what is the reason for the Clock skew, and how can I fix it, as I believe it prevents my /mavros/mocap/pose data to be transfered to the drone, and thus, to appear in the RTFs logfiles.
regards,
Christopher
Issue has also been posted on Github: intel-aero/meta-intel-aero:
https://github.com/intel-aero/meta-intel-aero/issues/275 Intel aero // Mavros - Clock skew detected · Issue # 275 · intel-aero/meta-intel-aero · GitHub
Community Manager
Hi Christopher,
Thanks for reaching out.
I was investigating regarding the Clock skew warnings and those warnings can be caused by a difference of milliseconds between your system time and the px4 time because the clock sync tolerances are low, also that the clock synchronization system is for onboard use, so you can disable it.
Please take a look at the following site for more details:
Hope this information helps.
-Yermi A.
