Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
Is there a way to factory reset the Intel Aero Flight Controller?
NCole4
 I used the terminal commands "cd /etc/aerofc/PX4" and "sudo aerofc-update.sh nuttx-aerofc-v1-default.px4" which results in the terminal output:
BIOS_VERSION = Aero-01.00.13
OS_VERSION = Ubuntu 16.04.6 LTS"
AIRMAP_VERSION = unknown
FPGA_VERSION = 0xc2
AeroFC firmware version = 3.5.3
/dev/ttyS1:
Updating firmware on AeroFC
Writing force bootloader pin...
Done!
Reading force bootloader pin...
Force bootloader pin value = 0x1
Loaded firmware for 41,0, size: 932900 bytes, waiting for the bootloader...
If the board does not respond within 1-2 seconds, unplug and re-plug the USB connector.
Found board 41,0 bootloader rev 5 on /dev/ttyS1
ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff type: ÿÿÿÿ
idtype: =FF
vid: ffffffff
pid: ffffffff
coa: //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////8=
sn: 0039003e3335511839343335
chip: 20016419
family: STM32F42x
revision: 3
flash 999424
Erase : [====================] 100.0%
Program: [====================] 100.0%
Verify : [====================] 100.0%
Rebooting.
Done!
Force bootloader pin value = 0x0
However QGroundControl does not connect and shows "waiting for vehicle connection." However in the QGC tool Mavlink Inspector I can see "Vehicle 2" with 1HZ heartbeat, etc. This tells me that the flight controller is NOT flashing because it should reset the parameters including the vehicle's mavlink MAV_SYS_ID back to "Vehicle 1" but in QGC it's still showing "Vehicle 2." So is there a way to factory reset the flight controller OR another way to flash it?
