Community
cancel
Showing results for
Search instead for
Did you mean:
RKura
Issue parsing output from rs_get_frame_data()
I am having a slight issue parsing the data from realsense library function rs_get_frame_data()
What I need to do is copy the output from rs_get_frame_data() into a local memory buffer and pass that buffer on to GStreamer. Here is my code:
struct rgb *rgb = ( struct rgb *) rs_get_frame_data( camera, RS_STREAM_COLOR, &e ); // get single frame from realsense camera
char *buffer = malloc(640*480*3); // allocates buffer large enough to hold a single frame coming from realsense
memcpy (buffer,rgb, sizeof(rgb));
Then pass buffer on to GStreamer:
GstBuffer *gstbuffer = gst_buffer_new_wrapped_full( ( GstMemoryFlags )0, buffer, SIZE, 0, SIZE, NULL, NULL ); // GStreamer does not seem to like this. SIZE = 640*480*3 for a single frame
struct rgb is a 3 character struct defined as
@struct rgb {
unsigned char r;
unsigned char g;
unsigned char b;
What am I doing wrong here ?
Any help is much appreciated.
best
Rohan
RKura
MartyG
If you can help answer the above question that would be great.
Rohan
MartyG
I sadly have no knowledge of programming GStreamer. I wonder if this link might provide useful insight though
https://developer.gnome.org/gstreamer/stable/gstreamer-GstBuffer.html GStreamer 1.0 Core Reference Manual: GstBuffer
Looking at the formatting of your code though:
You may have a misplaced bracket, as a couple of others using a similar line wrote it as
GstBuffer *gstbuffer = gst_buffer_new_wrapped_full( ( GstMemoryFlags(0)
I'm guessing you got your code from this article?
https://software.intel.com/en-us/articles/intel-aero-realsense-streaming-rgb-depth-data Code Sample: Broadcast RGB and Depth Data from an Intel® Aero Compute Board | Intel® Software
RKura
Marty,
That was a typo on my part. The code I have is what you have there. So thats good. Do you see anything going wrong with the type conversion ? i.e when I memcpy the struct rgb data into char * buffer ?
best
Rohan
MartyG
Another thing that got my attention was that you are trying to use a frames per second (FPS) speed of 3. I can see the possibility that this may cause an issue with the R200 camera, as the R200 has a minimum FPS of 30 and tries to force the speed to be 30 if you set it lower than that in your code. Ideally, you should only be using '30' or '60' (for RealSense camera resolutions that support 60 FPS - most of them are 30 FPS).
RKura
Hi Marty,
Where do you see a fps = 3 ? I have fps = 30 set in my rs_enable_stream command. The malloc for 640*480*3 is for HEIGHT = 640, WIDTH = 480 and 3 bytes per pixel.
Rohan
MartyG
I'm sorry if I misunderstood. But in RealSense SDK code, the 3rd number in a resolution bracket always refers to FPS (width, height, fps). So in RealSense code, if you want a 640x480 resolution at 30 FPS then you write it as (640, 480, 30).
RKura
I am bit confused now
I assume you are referring to the code here:
The 2nd line doing the malloc gets memory for a single frame which I would think is 640*480*3 bytes for reasons mentioned above. Then when we get the next frame (this code is executed in a loop while we do a rs_wait_for_frames), we malloc a new buffer for the next frame. Are you saying the malloc is incorrect ?
Rohan
MartyG
I am at a disadvantage because I do not have knowledge of GStreamer programming. However, when trying to look at a single frame of a live analysis, the usual procedure is to pause the analysis on a particular frame and then get the data of that frame, rather than try to grab a frame whilst the stream is moving.
RKura
Thanks Marty. I will take a look at the link you provided.
My question for the following line of code
struct rgb *rgb = ( struct rgb* ) rs_get_frame_data( camera, RS_STREAM_COLOR, NULL );
Does this point the structure pointer rgb to a single frame data (640*480 pixel stream) or does it point to a single pixel (3 byte rgb) in a frame ? I assume this points of a stream of pixels information in one frame that is returned by rs_get_frame_data. Just want to be sure.
best
Rohan
MartyG
My guess would be that this line of code refers to a frame rather than a pixel, since a query about a frame is what is contained in the instruction. From my research of GStreamer instructions, I think that if it was referring only to a pixel then the code would reference 'pixels' instead of 'frame'. This is entirely guesswork on my part though.
RKura
I agree. So thats not what it is.
RKura
MartyG
I wanted to let you know that I think I figured out what was going on here w.r.t the output from rs_get_frame_data(). Thanks for your help. Turned out something in my application was not receiving the buffers properly. Still facing the mavlink error on QGC thou which I have a separate thread for.
best
Rohan
MartyG
I'm pleased you made progress on one of your issues. A little encouragement can go a long way.
