Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
771 Discussions
Issues running the examples on the Intel Aero RTF Drone
AInte4
I am currently trying to perform autonomous flying development for my but I am having some problems running the examples from the Dronekit repository https://github.com/dronekit/dronekit-python on my Intel Aero Ready To Fly Drone. Every time i try to run any of the examples i get either timeout due to lack of connection after the
>>"Connecting to vehicle on: tcp:127.0.0.1:5760"
appears on my terminal, or i get
>>data link #0 lost
>>data link #0 regained
and then the drone fails to run the code file.
I have been able to do an autonomous take off using QGroundControl but I am unable to run any python script on the drone.
I hope someone can shed some light on the subject.
Thank you in advance,
Alexandra_C_Intel
Hi AInte4, Thank you for your interest in the Intel Aero drone. Are running the examples on a remote computer or on the drone? Regards, Alexandra
AInte4
Hi Alexandra,
On the drone, I have tried both by plugging a keyboard, screen and mouse to it as well as through an ssh connection
Alexandra_C_Intel
Hi Aintel4,
Could you please check if the mavlink service is running?:
sudo systemctl status mavlink-router
If that's running, could you try running our code and let me know if it works?
https://github.com/intel-aero/meta-intel-aero/wiki/04-Autonomous-drone-programming-in-Python#hello-w...
Alexandra
AInte4
Hi Alexandra,
I tried the:
commad, which gave me the following output:
● mavlink-router.service - MAVLink Router Loaded: loaded (/lib/systemd/system/mavlink-router.service; enabled; vendor preset: enabled) Active: active (running) since Wed 2019-02-20 16:00:59 CET; 21h ago Main PID: 792 (mavlink-routerd) CGroup: /system.slice/mavlink-router.service  └─792 /usr/bin/mavlink-routerd     Feb 20 16:01:05 aau-intel-aero-drone mavlink-routerd[792]: MAV_CMD_LOGGING_START result(1) is different than accepted   Feb 20 16:01:06 aau-intel-aero-drone mavlink-routerd[792]: MAV_CMD_LOGGING_START result(1) is different than accepted   Feb 20 16:01:07 aau-intel-aero-drone mavlink-routerd[792]: Invalid ULog Magic number, restarting ULog...   Feb 20 16:01:07 aau-intel-aero-drone mavlink-routerd[792]: Logging target system_id=1 on 00049-2019-02-20_16-01-07.ulg   Feb 20 16:01:07 aau-intel-aero-drone mavlink-routerd[792]: Invalid ULog Magic number, restarting ULog...   Feb 20 16:01:07 aau-intel-aero-drone mavlink-routerd[792]: Logging target system_id=1 on 00050-2019-02-20_16-01-07.ulg   Feb 20 16:01:09 aau-intel-aero-drone mavlink-routerd[792]: 25 messages to unknown endpoints in the last 5 seconds   Feb 20 16:01:14 aau-intel-aero-drone mavlink-routerd[792]: 1 messages to unknown endpoints in the last 5 seconds   Feb 21 13:32:37 aau-intel-aero-drone mavlink-routerd[792]: TCP connection [8] accepted   Feb 21 13:32:44 aau-intel-aero-drone mavlink-routerd[792]: TCP Connection [8] closed
So yes, according to this, the mavlink service is running.
As for the Hello World script you recommended, it ran as intended on the physical drone itself and this is the output from the terminal:
Arming motors: Unknown mode 'GUIDED' Waiting for arming to be finished >>> Takeoff detected >>> Exception in message handler for HEARTBEAT >>> mode 100925440 not available on mavlink definition Keeping motors armed for 5s >>> Exception in message handler for HEARTBEAT >>> mode 100925440 not available on mavlink definition >>> Exception in message handler for HEARTBEAT >>> mode 100925440 not available on mavlink definition >>> Exception in message handler for HEARTBEAT >>> mode 100925440 not available on mavlink definition >>> Exception in message handler for HEARTBEAT >>> mode 100925440 not available on mavlink definition >>> Exception in message handler for HEARTBEAT >>> mode 100925440 not available on mavlink definition Disarming
Thank you again for your assistance
Alexandra_C_Intel
Hi AIntel4, Could you please restart the service and try to run the code again? sudo systemctl restart mavlink-router Regards, Alexandra
AInte4
Hi Alexandra,
I tried restarting and after which I ran the
command again. I received the same output.
I've tried this several times now, with the same result.
Thank you for your help
Alexandra_C_Intel
Hi AIntel4, I recommend you to open an issue on the dronekit site, since you are having issues with the dronekit examples. Regards, Alexandra
AInte4
I tried doing that but i have not received any response from any one, so i am left pretty much stranded. Could it be something to do with the GPS?
Alexandra_C_Intel
Hi AIntel4, You can check the GPS signal with QGroundControl. Also, please make sure you have the software up to date: https://downloadcenter.intel.com/download/27833/Intel-Aero-Platform-for-UAVs-Installation-Files Regards, Alexandra
