Hi
I'm trying to connect lidar lite v3 to the COMPASS port - have tried coneecting through an i2c splitter as well as directly to the compass port with mag0 removed (doesn't seem to be a i2c splitter issue).
I do see the distance sensor in QGC MavLink inspector and see the data change, but the rate of change is extremely slow because of which the drone for example held at 1m the altitude measured is still 0.4m resulting in EKF HGT error.
In mavlink inspector it shows that the data is read at 10Hz but when actually seeing the value, it changes very slowly and gets stuck at the same value for 3-5 seconds.
I tried connecting the lidar lite to Arduino Uno again using I2C but here I can clearly see the data updating at around 400Hz (the default update rate of lidar lite v3).
Is the 10Hz sampling rate at compass port a fixed value? Should I be using telemetry port to get a higher update rate?
Aero version -
bios - 1.6.2
Flight controller - 1.8
Hello Ambika_Verma,
Thank you for your interest in the Intel Aero Ready to Fly drone and we apologize for the late response.
Could you please let me know if you have tried to use the Telemetry port using the pinout for the sensor from: https://docs.px4.io/en/flight_controller/intel_aero.html
Looking forward to your reply!
Thank you,
Eliza
Hello Ambika_Verma,
Could you please let me know if you require further assistance on this matter?
Thank you,
Eliza
