Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Mavlink Fails on Arm - Ardupilot
MAlfo
i have updated the autopilot to ardupilot 3.6.7 ... after a long battle trying to calibrate the compass (due to that for some reason... the compass dont work properly in ardupilot)
When y try to arm (Manualy, by a GroundControl.. or by python script) the mavlink_router crash with core dumped signal SEGV status 11/SEGV...
my case is similar to
hi. i have the same fail as in
https://forums.intel.com/s/question/0D50P00004GqzXfSAJ/mavlinkrouter-fails-when-arming-throttle-lose...
but.. i need ardupilot for some peripheral
JesusE_Intel
Hi MAlfo, I would like to reproduce your issue.Could you provide me the output of aero-get-version.py and the qgroundcontrol version you are using? Did you make any changes to the drones configuration after updating and calibrating? Regards, Jesus
MAlfo
hi jesus
the aero get-version.py give
Bios 1.06 (latest)
FC Firmware 3.67 (Ardupilot)
FPGA 0xC2 (latest)
OS Ubuntu 16.04 Kernel 4.4.76
i dont remember doing nothing in config... the only thing i did is adding a Qgc.conf in the mavlink-routered forder for adding a UDP connection in my local network
Currently... its seems that theh mavlink routered is broken.. i shutdown and start and still same error.
what i have been doing... is after ssh to the drone.. i start a mavproxy --master /dev/ttyS1 --baudrate 921600 --out xxxxxxxxx to generate a router and is working... and it doesnt disconect when i manually arm... o do a arm from QGC
regards
MA
JesusE_Intel
Hi MAlfo, I am not seeing this behavior on my drone. Could you try to re-install Ubuntu and update all the components. Try to see if it works correctly on the included px4 version 1.6.5. Regards, Jesus
