Community
cancel
Showing results for
Search instead for
Did you mean:
UGoya
Mavlink-Router is not working and Firmware version is coming unknown
Jump to solution
Hello
I am working on intel Aero RTF drone, I have set up the full drone mavlink-router was working as well as firmware version was showed up.
But Yesterday I reboot the drone now firmware version is coming unknown and the mavlink-router is also not starting up.
The screenshot of the status of mavlink-router:
The screenshot of the intel-aero-version:
Please help me with this, I am totally confused what happened after rebooting the drone that nothing is working now, before that everything was perfectly working.
Thanks and Regards
Utkarsh
Eliza_D_Intel
Hello UGoya, Since you have had this issue in a previous thread, will be possible to reinstall the OS, this time using Ubuntu 16.04.3, as this is the version that have been confirmed to work with the drone. You can find it here: http://old-releases.ubuntu.com/releases/16.04.3/ , by the name: ubuntu-16.04.3-desktop-amd64.iso Thank you and best regards, Eliza
Eliza_D_Intel
Hello UGoya, Thank you for your interest in the Intel Aero Ready to Fly drone. I notice that you FPGA version 0xc0, where it should be 0xc2. You are unable to connect to mavlink router because the FC is not recognized. And the reason why the FC is not recognized is most probably caused by the fact that you have an older version of FPGA. So I recommend you to firstly, update the FPGA with aero-rtf.jam as per: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup#flashing-the-fpga and after this to flash again the Flight Controller, as per: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup#flashing-the-flight-controller-r... Thank you and best regards, Eliza
UGoya
Hello Eliza
I have updated the FPGA version, and than again flashed the flight controller, but still the Firmware is coming to be unknown.
The screenshot of all the commands is:
And Mavlink-router is also not working.
So I am totally confused what is the problem present in the system
Thanks and Regards
Utkarsh
Eliza_D_Intel
UGoya
Hello
It means I have to install everything again and do the flashing of all the the components again.
Utkarsh
Eliza_D_Intel
Hello UGoya, Unfortunately, yes. The version 16.04.6 have not been test by us for Intel Aero RTF drone and Ubuntu 16.04.3 have been validated by Intel to work well with the drone. Thank you and best regards, Eliza
UGoya
Hello Eliza
I have installed everything again, and now everything is working fine.
Thanks for solving the issue.
Thanks and Regards
Utkarsh
