Community
cancel
Showing results for
Search instead for
Did you mean:
SOpte
New Contributor II
Network - Internet Access
Hi
After upgrading OS to last version 1.3.1, I am not able to connect to network in client mode.
After switching to client mode, I did the steps here : https://github.com/intel-aero/meta-intel-aero/wiki/08-Aero-Network-and-System-Administration# networking-internet-access 08 Aero Network and System Administration · intel-aero/meta-intel-aero Wiki · GitHub
No error message of fail is shown but the connection does not establish. I was able to connect before upgrading.
Anyone has the same issue?
Thank you,
Soubhi.
SOpte
New Contributor II
after I execute "set_net 1", I get the following :
wlan0: No enabled networks (2 disabled networks)
wlan0: No enabled networks - do not scan.
wlan0: state: INACTIVE -> INACTIVE
OK
"enable_net 1" does not show any error message.
Thank you.
Community Manager
Hi Soubhi,
Thanks for your interest in the Intel® Aero™ Platform for UAVs.
I'm sorry to hear that you are having issues with the Aero Internet access. Please let us investigate this issue and we will get back to you as soon as we have some useful information.
Have a nice day!
-Jose P.
Community Manager
Hi Soubhi,
I followed the steps in https://github.com/intel-aero/meta-intel-aero/wiki/08-Aero-Network-and-System-Administration 08 Aero Network and System Administration · intel-aero/meta-intel-aero Wiki · GitHub and I was able to have internet access on my Aero Compute Board. Could you be so kind to provide the outputs of the following commands:
- get_aero_version.py - cat etc/wpa_supplicant.conf - ping www.google.com
We will be waiting for your reply, have a nice day!
-Jose P.
SOpte
New Contributor II
Hi Jose,
I appreciate your help.
The output of get_aero_version.py :
BIOS_VERSION = Aero-01.00.12 Prod.OS_VERSION = Poy Aero 1.3.1 (Krogoth)
AIRMAP_VERSION = 1.8
FPGA_VERSION = 0xc0.
The output of wpa_supplicant.conf
ctrl_interface==/var/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
ping www.google.com:
bad address "www.google.com".
In the previous versions, I used just to edit wpa_supplicant.conf and set the configuration directly like :
netwrok = { ssid = "net_name" }
and It was working without any problem. Now, I tried the steps in Wiki and the previous method but both do not work.
Is there any log file that records the errors for network connection?
When I switch to client mode, no problem or message errors are shown and the AP is disabled (I cannot find the network from my personal PC).
And when I followed the steps in the wiki, the final result for each commands was "OK". I have just noticed after I execute "set_net 1", I get the following :
OK
Thank you,
Soubhi
SOpte
New Contributor II
Hi Jose,
Now, I tried to set a password for the network and the OS successfully connected to the Wi-Fi network. When the network is open (without password), It does not able to connect.Problem solved!
Thank you Jose!
Soubhi
Community Manager
Hi Soubhi,
I'm glad to know that you solved the issue! Thanks for sharing your results, it will be useful for other users connecting to open networks.
Have a great day!
-Jose P.
