Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
Not able to see USB boot option
yShi8
Hello~
I'm going to upgrade the Yocto and flashing BIOS, then install Ubuntu in my aero RTF, following the reference documents on Wiki;
I have already set an UEFI started USB key, But I couldn't found USB boot options in BIOS.
BTW, I've tried this on a laptop and it works well. What should I do?
Thanks!
From a beginner~
Community Manager
Hello 。。。,
Thank you for your interest in the Intel Aero Ready to Fly Drone.
Can you give us more details about the issue? What program did you use to create the USB key in order to flash the Operating System? What type of cable are you using to connect the USB key to the Intel Aero Ready to Fly Drone?
Alexandru
yShi8
Thanks for your attention!
I've changed an USB 2.0 disk and finally it could be identified.
Previously used an 3.0 version, maybe the cause of the problem.
Thank you very much~
