Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Optical Flow on Aero not working
wliu28
I connected the LIDAR Lite 3 to the AERO. And when checking in QGC, The topic DISTANCE_SENSOR is there and working normal except some noise.
I then ran the following commands from the terminal:
systemctl enable aero-optical-flow
systemctl status aero-optical-flow
and received the picture attached.
When looking in QGC on the widget QGroundControl>Widgets>MAVLink Inspector> ,
There is no topic named OPTICAL_FLOW_RAD.
the output of this command : get_aero_version.py is the second picture attached.
How can I fix my problem? In fact, I have two Aero Drones, and one is using PX4flow, so the second one should be equipped with Lidar as I excepted.
Thanks!
Community Manager
Hello Weiqi,
Thank you for your interest in the Intel Aero drone.
Your request has been received and is currently being investigated.
We will get back to you as soon as possible.
Octavian
wliu28
Thank you.
but I found that when I reboot my drone, optical flow works well. However then I shutdown it just for a full battery, and then power on, I got the same result as yesterday.
That's to say, sometimes it works but sometimes not.
And so I wondered, How on earth could I make it well?
Community Manager
Hello Weiqi,
Please make sure that your drone is activated as an access point (hotspot) when running this code and test it a few times this way.
It's possible you need the hotspot activated so let me know if this makes a difference.
Octavian
wliu28
I tried many times with my drone activated as an access point. Also, I test the code when drone connecting wifi in my office.
but the optical flow does not work. I think the hotspot activated or not makes no difference.
Thanks you.
Community Manager
Hello Weiqi,
Please try updating your Bios again, and also, from your first screenshot it look like the flight controller firmware shows as unknown.
Please flash your flight controller following these steps and then try again the optical flow:
https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup# flashing-the-flight-controller-rtf-only
Also make sure to follow the steps on Github for the optical flow and let me know what specific step are you having trouble with.
https://github.com/intel-aero/aero-optical-flow https://github.com/intel-aero/aero-optical-flow
Hope this helps.
Octavian
wliu28
Hi Octavian,
Thank you for your help.
Should I download the latest BIOS or the latest intel aero image to update my BIOS again?
I will try what you provide as soon as possible and then feedback.
Weiqi_liu
Community Manager
Hello Weiqi,
The bios version has recently been updated.
Please follow the steps here in order to update your Bios with the latest version:
https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup# flashing-the-bios
Octavian
wliu28
When I update my BIOS, I get an error shown below. It seems that rpm can not use directly on ubuntu. So the command should be change as:
$: alien aero-bios-01.00.13-r1.corei7_64.rpm
$: sudo dpkg -i aero-bios-01.00.13-r1.corei7_64.deb
Is it that?
Is there any special parameters need to be added?
Thanks!
Community Manager
Hello Weiqi,
That is indeed correct, you need to convert it to a deb package using alien, although, you need to install the .16 package not the .13 one.
Download the latest bios from here: https://downloadcenter.intel.com/download/27399/Intel-Aero-Platform-for-UAVs-Installation-Files?v=t
and run this command:
sudo alien -d -i .rpm
Then you can run the aero-bios-update command and reboot your drone.
Thank you for bringing this to our attention. We will take steps to correct the documentation.
Octavian
wliu28
Hi Octavian,
Sorry for my later reply.
But I think I should first remove the previous version (v1.00.13) and then install the latest (v1.00.16). what is the command for removing previous?
Thanks!
weiqi_liu
Community Manager
Hello Weiqi,
We've tested on Ubuntu and it updated properly without having to remove the previous version manually.
Octavian
wliu28
I am so sad that I get an error when running this command: sudo alien -d -i aero-bios-01.00.16-r1.corei7_64.rpm.
So what should I do?
Thanks!
wliu28
In addition, I flashed my flight controller following these commands:
cd /etc/aerofc/px4/
sudo aerofc-update.sh nuttx-aerofc-v1-default.px4
everything goes normal but the FC version is still unknown.
Thanks!
weiqi_liu
Community Manager
Hello Weiqi,
I'm not able to see the link you sent me.
If the error you are talking about has something to do with the architecture, you can follow these steps:
You need to modify the control file.
sudo alien -g package-name.rpm (this will generate a folder with the package contents) cd package-dir/ sudo nano debian/control
Now change the architecture (i386 in my case) to be the one you need. For example, I added the amd64 archicture and this is how the line ended up:
Architecture: i386, amd64
Last step:
sudo debian/rules binary
This will produce the .deb file.
In regards to the issue with the FC firmware, what I would recommend is to reinstall the Ubuntu image on Aero and then try to install the FC firmware again.
Octavian
wliu28
Hi Octavian,
Yes. the error I got was about the architecture. I found that you are talking about this issue:
And I did all you suggest there and got the same result with Coline.
As for FC firmware, so Must I reinstall ubuntu on my drone? you know, this means that I have to do all steps including installing some packages and so on. It is not difficult but time consuming.
Thank you for you help.
Community Manager
Hello Weiqi,
I understand it's time consuming, that's why I'm only suggesting this as a last resort.
Can you please provide me some screenshots with the output of this command:
sudo dpkg -i package-name.deb
and also the output when you try to flash the FC firmware?
Octavian
wliu28
In order to flash my BIOS, I followed these steps:
1. sudo alien -g aero-bios-01.00.16-r1.corei7_64.rpm
cd aero-bios-01.00.16/ (this step generated two folders, aero-bios-01.00.16 and aero-bios-01.00.16)
sudo gedit debian/control
but I can't find .deb anywhere in the aero-bios-01.00.16 folder or the dir of home. So I try:
2.
rpm2cpio aero-bios-01.00.16-r1.corei7_64.rpm | cpio -idmv
sudo mv BIOSUPDATE.fv /boot (also sudo cp /boot/BIOSUPDATE.fv /boot/efi/)
sudo reboot
but when I reboot, the aero-get-version.py still returns Aero-01.00.13.
The output of flashing FC firmware is shown in the pictures.
Community Manager
Hello Weiqi,
Let's check if the sensor is properly connected.
Please run this command in Qgroundcontrol, in the Mavlink console: ll40ls test i2c
and share with me the results.
Octavian
wliu28
It seems that there is something wrong with the I2C port.
Community Manager
Hello Weiqi,
Please try to recalibrate the sensors and make sure they are properly connected.
Octavian
