Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Optical flow thermal issue
DMadi
I am observing distortion in the optical flow camera when running the Poky Aero 1.6.1 O/S (BIOS 01.00.13). I had shown pictures of the distortion in a previous post. . At the time, we drew the conclusion that it was due to connector fatigue. However, we have done further research and the problem is definitely not connector fatigue. We plugged in a brand new camera and saw the same distortion even though the camera had only been plugged in once. That rules out connector fatigue.
We also used proper ESD mats and ESD wrist straps at all times. However, to test the effect of ESD, we took a working camera and zapped the camera directly with ESD (the jolt was strong enough to jump 1 cm and was visible). After multiple zaps the camera was still working with no distortion. Hence, the camera does not appear to be very ESD sensitive, which makes us inclined to think that ESD is not the issue.
Then we took the camera with distortion and tried to cool it with a fan. The distortion reduced a little, but did not disappear. If we heat the camera, the distortion definitely gets worse. When we put our entire drone in the freezer with a flashlight and stream the video to our PC, the distortion decreases until it disappears entirely. Hence, the distortion is definitely thermal related, even though the camera is never hot to the touch.
All of these tests were done with the Poky Aero 1.6.1 O/S. Not all cameras show distortion but we have seen the issue with multiple cameras now.
We then took the drone with the brand new camera that had distortion and downgraded the O/S to the Poky Aero 1.3.1 O/S. We did not change the hardware or camera connections at all. Running with the 1.3.1 O/S there was no distortion in the image, even over time.
It seems to me that the internal frame rate set by the Poky Aero 1.6.1 O/S (which I believe is 75 Hz) is too high and some, but not all, cameras are overheating and produce distorted output due to thermal issues. The Poky Aero 1.3.1 O/S, I understand, uses a lower internal frame rate of 30 Hz for the optical flow camera and that does not appear to cause thermal problems.
Is it possible to make this setting configurable or reduce the rate used in Poky Aero 1.6.1? We do not want to downgrade to the earlier O/S because of the improvements to 1.6.1, but we need the optical flow to work reliably, even if we have to work with a reduced frame rate.
Dan
JDiam3
DanMadill I am also running the Poky Aero 1.6.1 and observing the same distortion when streaming the downward facing camera to QGroundControl. Additionally when running "aero-optical-flow", there are many errors "FPS below minimum" – are you also getting this error?
DMadi
The output I get from aero-optical-flow does not show those errors. I get:
root@dan-aero1:~# aero-optical-flow
Parameters:
camera_device=/dev/v4l/by-path/pci-0000:00:03.0-video-index2
camera_id=1
camera_width=320
camera_height=240
crop_width=128
crop_height=128
flow_output_rate=15
mavlink_tcp_ip=127.0.0.1
mavlink_tcp_port=5760
focal_length_x=216.667694
focal_length_y=216.245697
[Debug] Initial exposure 850
[Debug] Initial gain 0
[Debug] Mavlink TCP initialized 127.0.0.1:5760
[Debug] Mavlink stream HIGHRES_IMU set to 250.0 Hz
Number of good matches: 20, desired: 20
Number of good matches: 11, desired: 1
Number of good matches: 14, desired: 11
Number of good matches: 6, desired: 2
Number of good matches: 5, desired: 1
[Debug] No new gyroscope data available
Dan
JDiam3
Interesting. My output shows that the "number of good matches" is less than the "desired." Perhaps this is being caused by my the low frame rate...
Community Manager
Hello Dan,
Thank you for your interest in our Intel products.
Your request has been received and is currently being investigated.
We will get back to you as soon as possible.
Octavian
JAcev3
Hello Octavian,
I am wondering if you got a chance to investigate the distortion issue we and few other customers are facing with the optical flow camera.
It seems that it's a thermal issue since putting the camera in the fridge and then testing it, resolves the distortion in the image.
Thank you,
Julio
DMadi
Hello Octavian,
Is it possible to run the optical flow camera driver from the Intel Poky v1.3.1 O/S on Intel Poky v1.6.1 (since it does not exhibit the thermal issues)? If so, which files need to copied from the v1.3.1 O/S to the v1.6.1 O/S? Downgrading to v1.3.1 is not a desirable option for us because of other important updates.
Dan
