Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
PX4 NSH connection
HLim10
How do I have an access to NSH console of PX4?
Community Manager
Hello hyon,
Thank you for your interest in the Intel Aero drone.
You can either start nsh shell QGroundControl directly (Analyze > Mavlink Console) or you can install MAVProxy by typing this command in a terminal:pip install MAVProxy
Launch the shell:
mavproxy.py --master=tcp:127.0.0.1:5760 --quadcopter Load the nsh module in MAVProxy withmodule load nsh
Start the nsh shell with
nsh start Let me know if this helps.
Alexandra
Community Manager
Hello hyon,
Launch the shell:
Alexandra
Community Manager
Hello hyon,
Was my answer helpful?
Do you have further questions?
Alexandra
HLim10
is there any physical port for nsh?
Community Manager
Hello hyon,
The Aero Flight Controller does not expose a physical connection to the NSH. You can access it via QGroundControl or Mavproxy.
You can check out this guide on how to communicate with a Pixhawk using the NSH:
http://ardupilot.org/dev/docs/interfacing-with-pixhawk-using-the-nsh.html http://ardupilot.org/dev/docs/interfacing-with-pixhawk-using-the-nsh.html
Alexandra
