Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
PX4FLOW and hovering
Community Manager
Was someone able to operate the px4flow according to
http://www.instructables.com/id/Intel-Aero-Drone-Altitude-and-Position-Hold-Using-/ ?
What firmare did you use on the PX4 and the FPGA?
What QGC version?
any other modifications?
Thank you
Community Manager
Hello Yoni,
Thank you for your interest in the Intel Aero drone.
Your request has been received and is currently being investigated.
We will get back to you as soon as possible.
Octavian
Community Manager
Community Manager
http://www.instructables.com/id/Intel-Aero-Drone-Altitude-and-Position-Hold-Using-/ http://www.instructables.com/id/Intel-Aero-Drone-Altitude-and-Position-Hold-Using-/ ?
What QGC version?
Thank you
Community Manager
Hello Yoni,
Thank you for your patience.
After flashing the aero-rtf_12c.jam and aerofc-v1_px4flow.px4 files this is the output we have:
BIOS_VERSION = Aero-01.00.13
OS_VERSION = Poky Aero (Intel Aero Linux Distro) 1.6.1 (pyro)"
AIRMAP_VERSION = 1.8
FPGA_VERSION = 0xc2
AeroFC firmware version = 1.5.0
Also for QGC we have the latest 3.3.0 version installed.
Hope this helps.
Octavian
Yoni_M_Intel
Hi Octavian,
Does the optical flow work? Is the drone hovering?
Thanks, Yoni.
Community Manager
Hello Yoni,
We were able to get the system working for us. We recommend
to check that the sensor is connected properly and that the correct .jam file is used because that one configures the telemetry port to expose an additional i2c interface.
If you are using the provided flight controller firmware, please tell me if the optical_flow_rad is showing in the MavLink Inspector.
Octavian
Yoni_M_Intel
Hi
Can you please upload or send us the correct code versions for the PX4 and FPGA?
mailto:mandel.yonatan@gmail.com mandel.yonatan@gmail.com
Thank you , Yoni.
Community Manager
Hello Yoni,
The correct versions can be downloaded from this article http://www.instructables.com/id/Intel-Aero-Drone-Altitude-and-Position-Hold-Using-/
After flashing both the FC firmware and FPGA you should see FPGA version 0xc1 and the FC firmware 1.5.0
Octavian
Yoni_M_Intel
Did you change any parameters through the QGC, for it to work?
Thank you, Yoni
Community Manager
Hello Yoni,
No, we did not change any parameters.
Octavian
Yoni_M_Intel
Hi Octavian,
Did you check that it works and hovers while flying?
Thanks, Yoni
Community Manager
Hello Yoni,
We aren't able to test the hovering in the lab right now, but we've tested successfully in the past and there are also other users who have successfully used it.
Please make sure your PX4 parameters are adjusted for whichever surface they're launching from as stated in the guide.
Octavian
Community Manager
Hello Yoni,
Do you require any more assistance with this issue?
Octavian
Yoni_M_Intel
Yes, it's still not working.
Can you please check once again in your lab and describe the workflow you went through for it to work?
Thanks, Yoni.
Community Manager
Hello Yoni,
Can you please describe more clearly what exactly isn't working so we can better help you?
Octavian
