I finally got a test SIM to try with my Aero setup on T-Mobile here in northern california . The card was provisioned as a pre-paid plan . I told T-mobile I wanted to try their network with an iPad. The card was provisioned with the following APN's
+CGDCONT: 1,"IPV4V6","alpha.mnc260.mcc310.gprs","",0,0,0,0,0,0
+CGDCONT: 2,"IPV4V6","phone","",0,0,0,0,0,0
When I popped the Sim into the Aero/Sierra Wireless 7345 setup (with some some basic 3" circuit board antennas . ( AT+CSQ returns : +CSQ: 3,20 for the signal strength.)
The cellular performance , and surf speed are awful (see ping times below).
Is there anything I can try with my configuration to speed this up. Will changing the APN to "fast.t-mobile.com" really make a difference? I am surprised the modem just connected without any initiation. Which PDP context did it pick for the connection?
~$ ping www.apple.com
PING e6858.dsce9.akamaiedge.net (23.62.159.145) 56(84) bytes of data.
64 bytes from a23-62-159-145.deploy.static.akamaitechnologies.com (23.62.159.145): icmp_seq=22 ttl=56 time=6466 ms
64 bytes from a23-62-159-145.deploy.static.akamaitechnologies.com (23.62.159.145): icmp_seq=23 ttl=56 time=7098 ms
64 bytes from a23-62-159-145.deploy.static.akamaitechnologies.com (23.62.159.145): icmp_seq=24 ttl=56 time=6862 ms
Here is my setup..
root@fadec:~$ ifconfig -a
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:16 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:276328 errors:0 dropped:0 overruns:0 frame:0
TX packets:276328 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:13826798 (13.8 MB) TX bytes:13826798 (13.8 MB)
sit0 Link encap:IPv6-in-IPv4
inet6 addr: ::22.167.92.154/96 Scope:Compat
inet6 addr: ::127.0.0.1/96 Scope:Unknown
inet6 addr: ::192.168.8.1/96 Scope:Compat
inet6 addr: ::192.168.7.2/96 Scope:Compat
UP RUNNING NOARP MTU:1480 Metric:1
usb0 Link encap:Ethernet HWaddr 72:03:f4:d2:3d:ae
inet addr:192.168.7.2 Bcast:192.168.7.255 Mask:255.255.255.0
BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
wlp1s0 Link encap:Ethernet HWaddr 00:c2:c6:d3:03:c4
TX packets:70 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:11089 (11.0 KB)
wwp0s20u3 Link encap:Ethernet HWaddr f6:02:d2:7f:b2:d7
inet addr:22.167.92.154 Bcast:22.167.92.255 Mask:255.255.255.0
inet6 addr: 2607:fb90:482:e004:f527:977e:6813:efa5/64 Scope:Global
inet6 addr: 2607:fb90:482:e004:1990:33c2:a9dd:ec09/64 Scope:Global
inet6 addr: fe80::26:83b5:aa01/120 Scope:Link
UP BROADCAST RUNNING NOARP MULTICAST MTU:1428 Metric:1
RX packets:147 errors:0 dropped:0 overruns:0 frame:0
TX packets:55719 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:16482 (16.4 KB) TX bytes:50571102 (50.5 MB)
OK
+CSQ: 3,20
root@fadec:~$ mmcli -m 0
/org/freedesktop/ModemManager1/Modem/0 (device id '8991082ec94bddf0b40b8d9156b77f8872590b93')
Hardware | manufacturer: 'Sierra'
| model: 'MBIM [1199:A001]'
| revision: 'FIH7160_V1.2_WW_01.1415.07'
| supported: 'gsm-umts, lte'
| current: 'gsm-umts, lte'
| equipment id: '01393700625xxxx
System | device: '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3'
| drivers: 'cdc_acm, cdc_mbim'
| plugin: 'Sierra'
| primary port: 'cdc-wdm0'
| ports: 'cdc-wdm0 (mbim), ttyACM0 (at), wwp0s20u3 (net)'
Numbers | own : '+1xxxx043242'
Status | lock: 'none'
| unlock retries: 'sim-pin2 (10)'
| state: 'connected'
| power state: 'on'
| access tech: 'lte'
| signal quality: '0' (cached)
Modes | supported: 'allowed: 2g, 3g, 4g; preferred: none'
| current: 'allowed: 2g, 3g, 4g; preferred: none'
Bands | supported: 'unknown'
| current: 'unknown'
IP | supported: 'ipv4, ipv6, ipv4v6'
3GPP | imei: '013937006256182'
| enabled locks: 'fixed-dialing'
| operator id: '310260'
| operator name: 'T-Mobile '
| subscription: 'unknown'
| registration: 'home'
SIM | path: '/org/freedesktop/ModemManager1/SIM/0'
Bearers | paths: '/org/freedesktop/ModemManager1/Bearer/0'
root@fadec:~$ nmcli device
DEVICE TYPE STATE CONNECTION
cdc-wdm0 gsm connected modem
sit0 iptunnel disconnected --
wlp1s0 wifi unavailable --
can0 can unmanaged --
usb0 ethernet unmanaged --
lo loopback unmanaged --
Hi Alexandra,
Here is the output:
A quick update however. I disabled the mavlink daemon, rebooted this morning, and the performance is fine for what I would expect from the XMM 7160 modem . I didn't change anything on the wireless configuration.
See some speed tests here:
http://www.speedtest.net/result/7890489858
http://www.speedtest.net/result/7890506582
http://www.speedtest.net/result/7890512431
http://www.speedtest.net/result/7890517030
The ping times and data rates are acceptable .
I think we can close this issue.
mmcli -m 0
| equipment id: 'XXXX37006256182'
| plugin: 'Sierra'
Numbers | own : '+XXXX2043242'
| state: 'connected'
| power state: 'on'
| access tech: 'lte'
| current: 'unknown'
root@fadec:~# mmcli -b 0
Bearer '/org/freedesktop/ModemManager1/Bearer/0'
Status | connected: 'yes'
| suspended: 'no'
| interface: 'wwp0s20u3'
| IP timeout: '20'
Properties | apn: 'phone'
| roaming: 'allowed'
| IP type: 'ipv4v6'
| user: 'none'
| password: 'none'
| number: '*99#'
| Rm protocol: 'unknown'
IPv4 configuration | method: 'static'
| address: '22.160.215.107'
| prefix: '24'
| gateway: '22.160.215.1'
| DNS: '10.177.0.34', '10.177.0.210'
IPv6 configuration | method: 'dhcp'
| address: 'fe80::26:8490:5001'
| prefix: '120'
| gateway: '16a0:d76b:fe80::1'
| DNS: 'fd00:976a::9', 'fd00:976a::10'
Hi Alexandra,
Here is the output:
mmcli -m 0
| plugin: 'Sierra'
| state: 'connected'
| power state: 'on'
| access tech: 'lte'
| current: 'unknown'
| suspended: 'no'
| IP timeout: '20'
| roaming: 'allowed'
| IP type: 'ipv4v6'
| user: 'none'
| password: 'none'
| number: '*99#'
| prefix: '24'
| prefix: '120'
