Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
ROS: rosdep init and access over https problem on Yocto
MChar14
Hi! I'm trying to setup ROS on Intel Aero
BIOS_VERSION = Aero-01.00.12_Prod
OS_VERSION = Poky Aero 1.3.1 (krogoth).
When i launch pre-made ros-launch files such as r200_nodelet_default.launch i have messages like "rosdep view is empty: call 'sudo rosdep init'". Ok, "rosdep init" is a common command you should run before starting to work with ROS. So i tried to init rosdep, but had an error: "cannot download default sources from: https://raw.githubusercontent.com/.../20-default.list. Website may be down."
Website is definitely not down and from intel aero i can ping it. After some time i figured that i cannot connect from Intel Aero to any site via https (433).
Is there any way to get access via https to internet from IA?
Thanks!
Community Manager
Hello mike_charikov,
Thank you for your interest in the Intel® Aero Compute Board.
When I select the link that you provided ( https://raw.githubusercontent.com/.../20-default.list) I get the following message:
400: Invalid request
Are you sure that is the correct address?
Andres V.
MChar14
Oh, i just shorten the path in a post.
The problem is that i cannot connect from Intel Aero to any site via https".
For example i can connect to http://www.google.com but i cannot connect to https://www.google.com.
root@intel-aero:~# wget http://www.google.com
Connecting to www.google.com (173.194.122.241:80)
Connecting to www.google.ru (74.125.232.255:80)
index.html 100% |***************************************************************************************************************| 10952 0:00:00 ETA
root@intel-aero:~# wget https://www.google.com
Connecting to www.google.com (173.194.122.242:443)
wget: error getting response: Network is unreachable
No other desktop in this network has such a problem.
Any ideas why this can happen? Can you try to reproduce it?
Because of this problem command "sudo rodep init" doesn't work as it tries to connect to https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
Mike
Community Manager
Hello Mike,
I reproduced your example and got the same error message.
I'll be needing more time to investigate what may be the reason behind this.
As soon as I have relevant information I'll contact you through this post.
Thank you for your patience.
Andres V.
Murilo_P_Intel
The problem is related with this: https://github.com/intel-aero/meta-intel-aero/issues/127 Update Mavros to v0.18.x to get MAVLink 2 for logging with ULogger · Issue # 127 · intel-aero/meta-intel-aero · GitHub
Community Manager
Hello Mike,
Sorry for the late reply.
The wget command used in the Aero is a partial version provided by busy box, and it does not deal with https properly.
You may want to try one of the following alternatives:
1. build wget from source and include it in the image.
2. use wget in the docker container, installing it by running apt-get install wget.
3. use the curl command, curl https://www.google.com.
If you have another question or update, don't hesitate to contact us.
Have a nice day.
Andres V.
