I bought and received RTF. I tried to connect QGround Control using wifi access. I am not able to see wifi access point. Do I need to flash my drone or RTF should able to show wifi access point? Before flashing I wanted to check application and some flight fly experience with already calibrated drone.
Thanks and Regards,
Bhaskar
Hello Bhaskar,
Thank you for your interest in the Intel Aero drone.
You will need to first set up the drone, install the OS and update it by following this guide: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup
You can also install Ubuntu with this guide if you prefer: https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation
The drone, by default, should start as an access point when you boot it up.
You can find more information here on how to enable and disabled the access point:
https://github.com/intel-aero/meta-intel-aero/wiki/08-Aero-Network-and-System-Administration
Hope this helps.
Octavian
Hello Bhaskar,
Hope this helps.
Octavian
Hello Bhaskar,
Do you require any more assistance with this issue?
Octavian
Thanks for your replaying,
I am able to connect to QGround Control using wifi access on windows 10 using wifi access. However it was not showing battery status. Do I need to some configure for battery status.
Hello Bhaskar,
In order to view the battery status you will need to follow the steps listed in the following link:
https://docs.qgroundcontrol.com/en/SetupView/Power.html
This Power setup is used to configure the battery parameters.
You will most likely also require a multimeter in order to measure the voltage from the battery.
Please let us know if we can assist with any further information.
Bogdan
I tried to fly my drone and it crash landed. Unfortunatly I lost three wings in the process. Do we need to upgrade the firmware for stable flight. I tried with position hold and just take off and landing but drone was moving forward very fast even though I was not doing anything with right joy stick( Movement control). It was not properly tuned and unstable..
Hello Bhaskar,
Yes, you will need to update the BIOS, Firmware and FC software.
For assistance in this matter you can check out the following link: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup
Let me know, if you require further assistance.
Casandra
Hello Bhaskar,
Can you tell me if the solution provided was helpful?
Is there anything else I can help you with?
Casandra
Ya , Thanks for your support and reply. For now I don't have any quetion. I will update firmware and try it. Thanks for your support.
