I'm using drone almost as-bought, I only upgreaded:
OS to: Poky Aero 1.6.0
FPGA to: 0xc2
BIOS to: Aero-01.00.13
AeroFC to: 1.6.5
I have read almost all articles from: https://github.com/intel-aero/meta-intel-aero/wiki Home · intel-aero/meta-intel-aero Wiki · GitHub
but I had some troubles along the way.
For example:
1.
sudo v4l2-ctl --list-devices
v4l2-ctl: command not found
2.
cpp-enumerate-devices
cpp-enumerate-devices: command not found
3.
The same goes for "cpp-headless"
I do have however files like:
cpp-capture
Also I cloned repository: https://github.com/IntelRealSense/librealsense/tree/v1.12.1 GitHub - IntelRealSense/librealsense at v1.12.1
but programs from ./examples won't compile
g++ cpp-tutorial-2-streams.cpp
gives error "no such file or directory # include "
and compiling cpp-headless.cpp: gives errors like "undefined reference to rs_*"
(I checked, and yes, there is file /usr/include/librealsense/rs.hpp)
Any help is highly appreciated
Hi MateuszF,
Thank you for your interest in the Intel Aero Platform. Some librealsense examples are not included on the aero image. You will need to build them from source, some packages like cmake and libusb are required. I would recommend you to install Ubuntu on Aero in order to develop RealSense applications.
You can find the Ubuntu installation instructions here:
https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation
Make sure to use the legacy branch of librealsense, as the latest does not support the Intel RealSense R200 Camera.
https://github.com/IntelRealSense/librealsense/tree/legacy
https://github.com/IntelRealSense/librealsense/blob/legacy/doc/installation.md
Jesus
Hi MateuszF,
Jesus
Hi Jesus,
I'll probably switch to Ubuntu to make my life simpler, but I need to ask anyway: Is there an almost-not-terrible way of programming IntelAero on yocto project or on laptop and importing programs to IntelAero?
And regarding switching to Ubuntu, is there any guide on how to revert back to previous state (Yocto with programs from IntelAero) if needed?
Mateusz F
Hi Mateusz,
I am not sure if there is a cross compiler for librealsense. To switch back to Yocto, you will simply need to create a bootable USB drive as mentioned in https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup# flashing. Once you boot into the USB, just select install.
Hope this helps!
Jesus
