Community
cancel
Showing results for
Search instead for
Did you mean:
ACast26
RTF simulation in ROS Gazebo
Jump to solution
I am trying to simulate the RTF drone in Gazebo with ROS. I know there is still no model for the drone, but I'd like to perform simulations with a generic drone model and the R200 camera. How can I perform a simulation with the most approximated drone model to the RTF in Gazebo?
André Castro.
Community Manager
Hi André,
Thank you for your interest in the Intel Aero Platform. I have not tried Gazebo simulator myself but I would recommend for you to find a drone model with the Aero RTF Drone specifications listed in the following link under Details -> "Other Specifications." Some details from the page include weight, dimensions, propeller length, etc.
https://click.intel.com/intel-aero-ready-to-fly-drone.html
Hope this helps!
Jesus
Community Manager
Hi André,
Hope this helps!
Jesus
ACast26
Hi, Jesus,
thanks for the reply. I was reading http://https//communities.intel.com/thread/120508 this other thread and that guy was trying something similar. I adapted one of the ROS http://wiki.ros.org/hector_quadrotor/ packages to load a drone model with the R200 camera. Since you send me all the drone specifications, I'll try to create a drone model very similar to it. Thanks!
BSzeb
Hi Andre,
Could you make the drone model you created available on github (or elsewhere)? I would really appreciate it.
Bence
ACast26
Hey, chillax .
I´m sorry for the late reply. I tried to create a model as similar as to the RTF, but at the end, I just adapted an existing one.
Install the following to get the R200 model.
https://github.com/IntelRealSense/realsense_samples_ros/tree/kinetic-devel/realsense_ros_camera https://github.com/IntelRealSense/realsense_samples_ros/tree/kinetic-devel/realsense_ros_camera
In the next link, you can find the drone model with the attached R200. https://github.com/Andreluizfc/quadrotor_r200_gazeebo GitHub - Andreluizfc/quadrotor_r200_gazeebo: Gazeebo models for quadrotor with R200 camera
Hope it helps! Best of luck,
André Castro.
ICarr1
Hi Andreluizfc Does your model include a launch file for executing it on gazebo??
ACast26
I ended up not using a simulation, so the files I have are incomplete. You need to adapt many things.
You can find https://github.com/tu-darmstadt-ros-pkg/hector_quadrotor/blob/kinetic-devel/hector_quadrotor_gazebo/... here a simple launch file using a generic camera. I recommend reading the http://wiki.ros.org/urdf/Tutorials urdf/Tutorials - ROS Wiki also.
Cheers,
André Castro.
