Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Reading video/images from the down facing camera in the Aero in Ubuntu
I would like to read video/images from the down facing camera in the Aero, while using Ubuntu.
Can this be done with Opencv or Mavros?
If not,what are the alternatives?
Thanks, Yoni.
Community Manager
Hello Yoni,
Thank you for your interest in our Intel products.
If you are connected to Intel Aero graphically, with a HDMI cable, you can run a graphical tool. The simplest tool is gstreamer:
sudo gst-launch-1.0 v4l2src device=/dev/video13 ! xvimagesink
You can play around with the settings, like changing to VGA, 30fps:
sudo gst-launch-1.0 v4l2src device=/dev/video13 ! video/x-raw,width=640,height=480,framerate=30/1 ! xvimagesink
For a more user friendly tool, install guvcview with sudo apt install guvcview on Ubuntu. Remember, there's 3 feeds for the R200 Camera. Select the third one for the color output.
You can find more information here: https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video
Hope this helps.
Octavian
Community Manager
Dear Octavian,
I'm sorry but you haven't answered my question.
Thanks, Yoni.
Community Manager
Hello Yoni,
Maybe this can help you. https://github.com/intel-aero/sample-apps/pull/1 Optical Flow (OpenCV) using downward facing VGA camera via V4L2 by broody · Pull Request # 1 · intel-aero/sample-apps · G…
It grabs raw frames from the downward facing VGA camera via V4L2 and then feeds it to OpenCV to do optical flow.
I don't think you can use Mavros to help you with reading video/images from the camera.
Octavian
Community Manager
Hello Yoni,
Has your issue been resolved?
Octavian
Community Manager
Hi Octavian,
Not really.
Is there a way to read the down facing camera with Opencv, while using Ubuntu?
Thanks, Yoni.
Community Manager
Hello Yoni,
Please take a look at the sample code below:
https://github.com/intel-aero/aero-optical-flow/tree/master/src https://github.com/intel-aero/aero-optical-flow/tree/master/src
This example code is using Yocto, at this time the down facing camera does not function properly in Ubuntu. An alternative would be to use the RealSense camera as described in this guide: http://www.instructables.com/id/Intel-Aero-Drone-Downward-Facing-RealSense-Camera http://www.instructables.com/id/Intel-Aero-Drone-Downward-Facing-RealSense-Camera
Hope this helps.
Octavian
Community Manager
It does.
Thank you.
SArgy
I also need to have access to the raw images from the down facing camera using Ubuntu and OpenCV.
Please update this topic when there is support for Ubuntu.
Community Manager
See here
Though the video is not so good
SArgy
@Yoni,
Did this code actually work for you? Because I still get a totally grey picture ...
