Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
Replacing GPS post
CRamé
I broke the GPS post on the Intel Aero. Is there a reference number to buy a replacement? Yuneec sells the full GPS module (http://us.yuneec.com/Aero-Drone-GPS-compass-module Typhoon H GPS Module Set | Yuneec USA ), but I only need a new post.
Also, would you know the inner diameter of the set screw closest to the GPS? I was able to remove the one at the bottom with a 1.5mm hex key, but I'm having some trouble with the one at the top.
Community Manager
Hi Coline,
Thank you for your interest in the Intel Aero drone.
Unfortunately, you will have to replace the whole module:
https://click.intel.com/intel-aero-drone-spare-parts.html
You can replace it with any GPS. as long as it is sending NMEA messages:
https://github.com/intel-aero/meta-intel-aero/issues/303%23issuecomment-361649979 https://github.com/intel-aero/meta-intel-aero/issues/303# issuecomment-361649979
The GPS module is designed by Yuneec. You will have to reach out to them for more information.
Alexandra
Community Manager
Hi Coline,
Alexandra
