Community
cancel
Showing results for
Search instead for
Did you mean:
CChen147
The compass is fail to connect after drone fell down.
The drone still can be connected by remote controller or laptop.
We thought the porblem might be happened with component had broken.
If thus,does anyone got same situation or better way to figure out with it!
The following is what we did:
1. Connection test with two OS(ubuntu,yocto)
2. also update both firmware of ardupilot and PX4 to test it
3. more details:
BIOS_VERSION = Aero-01.00.13
OS_VERSION = Ubuntu 16.04.3 LTS
FPGA_VERSION = 0xc2
PX4 4.4.76-aero-1.2
thanks a lot!
Community Manager
Hello Cc x,
Thank you for your interest in the Intel Aero drone.
Have you tried calibrating the drone by following this guide?
https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-setup# calibration
Please share the error message you're getting or a screenshot if possible.
Also, make sure your PX4 firmware is updated to the latest version.To update the flight controller use the following command:cd /etc/aerofc/px4/ aerofc-update.sh nuttx-aerofc-v1-default.px4You can also flash a new version of the firmware directly from the https://github.com/PX4/Firmware/ PX4 repository. Follow the instructions on their https://dev.px4.io/hardware-intel-aero.html wiki for that.
If the issue still persists after this, you can try reflashing the image on the aero drone.
Hope this helps.
Octavian
CChen147
Hi Octavian:
Thanks for your information!
We'd tried to reflash OS and update the firmware of PX4 before.
Unfortunately,it still not work.
What we doing is try to replace the broken component(hardware) and see how's happen after that.
I'll keep post the result that we done.
thanks!
C.C.
Community Manager
Hello C.C.
Thank you for your reply. I will be waiting for your update.
In the meanwhile you can find spare parts for Aero here: https://click.intel.com/intel-aero-drone-spare-parts.html
Octavian
