Community
cancel
Showing results for
Search instead for
Did you mean:
MTava2
USB CAMERA WITH OPENCV
how can i see from a usb camera with opencv?
My usb camera is /dev/video14
and I would like to see from the usb camera with the following code:
import numpy as np
import cv2
cap = cv2.VideoCapture(0)
while(True):
# Capture frame-by-frame
ret, frame = cap.read()
# Our operations on the frame come here
gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
# Display the resulting frame
cv2.imshow('frame',gray)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
# When everything done, release the capture
cap.release()
cv2.destroyAllWindows()
I know that with the r200 this code is used
import logging
logging.basicConfig(level=logging.INFO)
import time
import numpy as np
import cv2
import pyrealsense as pyrs
from pyrealsense.constants import rs_option
with pyrs.Service() as serv:
with serv.Device() as dev:
dev.apply_ivcam_preset(0)
try: # set custom gain/exposure values to obtain good depth image
custom_options = [(rs_option.RS_OPTION_R200_LR_EXPOSURE, 30.0),
(rs_option.RS_OPTION_R200_LR_GAIN, 100.0)]
dev.set_device_options(*zip(*custom_options))
except pyrs.RealsenseError:
pass # options are not available on all devices
cnt = 0
last = time.time()
smoothing = 0.9
fps_smooth = 30
while True:
cnt += 1
if (cnt % 10) == 0:
now = time.time()
dt = now - last
fps = 10/dt
fps_smooth = (fps_smooth * smoothing) + (fps * (1.0-smoothing))
last = now
dev.wait_for_frames()
c = dev.color
c = cv2.cvtColor(c, cv2.COLOR_RGB2BGR)
d = dev.depth * dev.depth_scale * 1000
d = cv2.applyColorMap(d.astype(np.uint8), cv2.COLORMAP_RAINBOW)
cd = np.concatenate((c, d), axis=1)
cv2.putText(cd, str(fps_smooth)[:4], (0, 50), cv2.FONT_HERSHEY_SIMPLEX, 2, (0, 0, 0))
cv2.imshow('', cd)
break
but I throw this error when I run the code, I guess the error comes out because it is not the r200, how could my camera usb work, by the way I've already tried it and if it captures photos
Tags (1)
Community Manager
Hi MarioTavarez,
Thank you for your interest in the Intel Aero drone.
Please let me look into it and I will get back to you later.
Alexandra
Community Manager
Hello MarioTavarez,
As stated in the package description, MacOS and Linux packages do not support video related functionality (not compiled with FFmpeg). You will have to compile OpenCV manually.
Let me know if you have further questions.
Alexandra
MTava2
I have already compiled opencv before including opencvcontrib that contains its extra modules that I use and I need to use in the intel aero but I mark that error when I run that little script on the camera, I do not know if I take it as the main camera, I just need to Call usb camera through an opencv videocapture function but it does not work
Community Manager
Hi MarioTavarez,
I am still investigating your issue.
Could you tell me what camera model do you have?
Alexandra
MTava2
I found the solution to the problem, in the videocapture () function you have to pass the path of the device in this case I want to use the 14 ie the usb camera, therefore I put this code in case you are interested in documenting
import numpy as np
import cv2
cap = cv2.VideoCapture('/dev/video14') # In this part I put the route camera
while(True):
break
cap.release()
