Trying to get a USB serial device to work on the intel aero. When I plug it in I see the device is recognized but not serial port is enumerated. Am i correct is assuming no usb serial drivers are compiled into the intel aero yocto kernel? I can't see any under /lib/modules//kernel/drivers/usb/serial
Trying to install ubuntu to get around this if what i understand is correct
Dion
Hello dgonano,
Thank you for your interest in the Intel Aero Compute Board.
Could you please let me know which USB serial device are you trying to use and the output of aero-get-version.py ?
Also, if it's possible can you share more details about what are you trying to do with the USB serial device?
Thank you in advance,
Eliza
Hi Eliza,
Please see details below. It's a VCP connected via USB on the RTF Drone. Everything has been updated
root@intel-aero:~# lsusb -D /dev/bus/usb/001/002
Device: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x10c4 Cygnal Integrated Products, Inc.
idProduct 0xea60 CP210x UART Bridge / myAVR mySmartUSB light
bcdDevice 1.00
iManufacturer 1 Silicon Labs
iProduct 2 CP2102 USB to UART Bridge Controller
iSerial 3 0001
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 2 CP2102 USB to UART Bridge Controller
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
can't get debug descriptor: Resource temporarily unavailable
Device Status: 0x0000
(Bus Powered)
root@intel-aero:~# aero-get-version.py
BIOS_VERSION = Aero-01.00.16
OS_VERSION = Poky Aero (Intel Aero Linux Distro) 1.6.2 (pyro)"
AIRMAP_VERSION = 1.8
FPGA_VERSION = 0xc2
AeroFC firmware version = 1.6.5
Cheers
Dion
I can see the USB device obviously, but I can't see the serial port, I'm assuming the aero doesn't have the driver
Hello dgonano,
It is possible that the driver is not included in the Yocto image.
Could you please try to add the driver or try to use the usb/serial device with Aero running Ubuntu and see if the driver is included?
Casandra
Confirming no USB serial drivers are included in the yocto image. This is unbelievable, very useful for embedded linux development.
Ubuntu included them and working fine using the generic kernel
