Community
cancel
Showing results for
Search instead for
Did you mean:
RRoma8
USB3 Interface
Jump to solution
Is it possible to connect USB3 Vision cameras to the USB OTG port?
Thank you,
Roman
Tags (1)
Community Manager
Hi Roman,
Thanks for reaching out.
According to this guide: https://software.intel.com/sites/default/files/managed/25/d5/Intel-Aero-Compute-Board-Getting-Starte..., the USB port is 3.0, so I think you should have problems connecting the camera, but you need to install the right drivers on the image.
If you need more help with it, please provide us more information about your project.
Have a nice day.
-Leonardo
Community Manager
Hi Roman,
Have a nice day.
-Leonardo
RRoma8
Dear Leonardo,
Thank you for your reply.
I have just figured out that the board lacks IMU and PWM, i.e., an external FCU is required anyways.
Hence, probably Joule would be a better choice for our project - it's in the area of industrial inspection using vision based drone navigation.
I would appreciate if you could compare Intel Aero Platform to Intel Joule (MIPI interface aside).
Thank you,
Roman
Community Manager
Hi Roman,
Just to clarify, the Aero contains an IMU in its board, and yes you have to use a Flight Controller with it.
About the comparison, these are 2 different boards with different features, you can find the information of each one in the following links:
Intel® Joule™: https://software.intel.com/en-us/iot/hardware/joule
Intel® Aero Compute Board: https://software.intel.com/en-us/aero/dev-kit
I hope you find this information helpful.
-Leonardo
