Is there someone using PX4FLOW sensor on Aero RTF drone?
I installed PX4FLOW on aero foll0wing this:http://www.instructables.com/id/Intel-Aero-Drone-Altitude-and-Position-Hold-Using-/ Intel Aero Drone - Altitude and Position Hold Using PX4Flow: 11 Steps (with Pictures) and everything is OK other than the frequency of the output. The output rate is only 0.5 HZ(I know it from QGroundControl). How can I modify the output rate?
Thanks!
Are you using qgroundcontrol to view this? And are you connecting via a telemetry radio?
If yes, then I saw a similar problem. You might try connecting qgroundcontrol via wifi (udp or tcp) and see if you get different results. (expect around 10hz)
I was able to get better radio telemetry performance by changing how mavlink gets initialized on the flight controller (rebuilt firmware and re-flashed)
Details:
In this file:
./Firmware/ROMFS/px4fmu_common/init.d/rcS
change this line:
set MAVLINK_F "-r 1200 -d /dev/ttyS3"
To this:
set MAVLINK_F "-d /dev/ttyS3 -b 57600 -r 2880 -m onboard"
Alternatively, you could update the stream rate directly in the code for the desired mode....
See file: /Firmware/src/modules/mavlink/mavlink_main.cpp
and look for:
configure_stream("DISTANCE_SENSOR", 0.5f);
configure_stream("OPTICAL_FLOW_RAD", 1.0f);
Hope that helps.
- Randy
Hi RandyK,
Thanks a lot for your reply!
but I can not find the file: /Firmware on my drone. In addition, I flash my FC referring to this::http://www.instructables.com/id/Intel-Aero-Drone-Altitude-and-Position-Hold-Using-/ Intel Aero Drone - Altitude and Position Hold Using PX4Flow: 11 Steps (with Pictures), and then all the output rate(see from qgroundcontrol) has been limited including HIGH IMU , ALTITUDE and so on. Do you know why?
Thanks again.
-Liu
Sorry I was not clear. I downloaded the source code and re-built the flight controller firmware on a desktop linux system (Ubuntu).
Here's How I got the source, how I build it, and how I update or re-flash the drone...
Get the source...
cd ~
mkdir px4
cd px4
git clone https://github.com/PX4/Firmware.git https://github.com/PX4/Firmware.git
Here's how I build it...
cd ~/px4/Firmware
make nuttx_aerofc-v1_default
The previous step creates the following file:
~/px4/Firmware/build/nuttx_aerofc-v1_default/aerofc-v1_default.px4
Then I copy that to the drone (via wifi), I shell into the drone and update the firmware. For me, that looks like this:
copy it...
scp ~/px4/Firmware/build/nuttx_aerofc-v1_default/aerofc-v1_default.px4 root@YOUR_DRONE_IP:/etc/px4-fw/aerofc-v1_default.px4
shell into the drone...
ssh root@YOUR_DRONE_IP
cd /etc/px4-fw
aerofc-update.sh aerofc-v1_default.px4
The update procedure is flaky, so you might have to try that last step a few times if it appears to be stuck in a loop for more than a minute.
I'm not an expert. I'm still trying to get my head around this stuff, but that's what works for me.
Might be related to the band width of your connection in qgroundcontrol.
- Randy
