Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
Ubuntu packages
ICarr1
Hi all,
I have installed Ubuntu on my RTF drone I followed the steps from https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation https://github.com/intel-aero/meta-intel-aero/wiki/90-(References)-OS-user-Installation but in the step at the moment that I made apt-get update
showed me the next message:
About the architecture i386... then I continued with the steps I everything seemed to be ok, but each time I make apt-get update shows me that message... Is something wrong??
Community Manager
Hi ivanalexo,
Thank you for your interest in the Intel Aero drone.
Make sure you add the Intel Aero repository (and key) to your sources.
Could you run these commands and send me a print screen of the output?:echo 'deb https://download.01.org/aero/deb xenial main' | sudo tee /etc/apt/sources.list.d/intel-aero.list
wget -qO - https://download.01.org/aero/deb/intel-aero-deb.key | sudo apt-key add -
Alexandra
ICarr1
Here is the output:
And this one when I made apt-get update
Community Manager
Hi ivanalexo,
Thank you for the photos.
Could you also send me the output of this command?sudo apt-get upgradeYou can ignore the message received at the end of the output in your screenshot and continue following the steps in the guide. You got that message because the update process took only the files for the 64 bit version.
Alexandra
ICarr1
Hi Alexandra,
this is the output of the command apt-get upgrade
Thanks for the reply, everything is working on
