Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
776 Discussions
Ubuntu video devices & stream
Community Manager
Can anyone tell me which device is which while running Ubuntu on drone and how to stream using gstream a camera other than the realsense ones (video[11 - 13])?
ls /dev/video* returns all devices but can't understand which one is the camera below realsense
Is there an app or way to test it? Like choosing devices to see what they shoot live.
Community Manager
Hello Sotiris,
Thank you for your interest in the Intel Aero drone.
On Ubuntu, Intel Aero is proposing 3 RTSP video feeds:
  • RealSense R200, infrared first camera: rtsp://AERO_IP_ON_YOUR_NETWORK:8554/video11
  • RealSense R200, infrared second camera: rtsp://AERO_IP_ON_YOUR_NETWORK:8554/video12
  • RealSense R200, HD camera: rtsp://AERO_IP_ON_YOUR_NETWORK:8554/video13
There is also a black and white camera but that one will not appear when you list the devices if you have Ubuntu installed.
You can access the camera with /dev/video2 but can't stream this device with gstreamer. Instead, you can download a sample code from https://github.com/intel-aero/sample-apps/tree/master/capturev4l2 https://github.com/intel-aero/sample-apps/tree/master/capturev4l2 to see how you can capture a few frames to raw format, then output jpg frames:
git clone https://github.com/intel-aero/sample-apps.git cd sample-apps/capturev4l2/ make C=10 INPUT=1 MODE=PREVIEW ./capture_v4l2 --userp -d /dev/video2 ffmpeg -f rawvideo -s 640x480 -pix_fmt yuv420p -i Image-video<*> test.jpg
Typical use for the camera include https://github.com/intel-aero/aero-optical-flow optical flow and https://github.com/intel/camera-streaming-daemon/blob/master/src/stream_aero_bottom.cpp Camera Streaming Daemon
Driver is not fully v4l2 compliant. Using opencv or gstreamer with the camera device node to grab camera frames will not work. The sequence of operation as shown in the sample needs to be done. Polling on device file descriptor times out after certain interval. This requires the device to be restarted.
You can find more info on our wiki: https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video# take-a-photo-with-the-black-and-white-camera
Hope this helps.
Octavian
Community Manager
Hello Sotiris,
Hope this helps.
Octavian
Community Manager
Hello Sotiris,
Do you require any more assistance with this issue?
Octavian
Community Manager
No, thank you very much!
