What is the TCP or UPD port for connecting to qgroundcontrol? I can join wifi but qgroundcontrol does not automatically connect to Intel Aero.
- Tags:
- Intel® Aero Platform
Hi AAkta,
Thank you for your interest in the Intel Aero drone.
Is the laptop you have QGroundControl installed on connected to the Aero drone's access point?
Alexandra
Yes I use QGroundControl 3.5.0. Using wireshark I found UDP ports as 58314 drone side and 14550 pc side, but still cannot connect to QGroundContol neither automatically nor manually.
Hi AAkta,
The PC has to be connected to the Aero WiFi access point (Called "Aero") as described here https://github.com/intel-aero/meta-intel-aero/wiki/08-Aero-Network-and-System-Administration#network...
Also, please make sure that you disable any firewall or VPN service on the computer that is running QGrounControl.
To enable video streaming, please follow the instructions here https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video#rtsp-video-streaming-from-yo...
Alexandra
