Hello
The problem I met is that after I land the RTF under position control using RC and pull the throttle all the way down, the motors doesn't slow down to a safe level so I can disarm (throttle down and yaw left) immediately, but still running at a relative high speed, and RTF becomes unstable on the ground, but after a while (maybe 10-20 second) the motors slow down and I can safetly disarm it.
This happened after I upgrade all the stuff to the newest.
So do I need to re-configure the RC or is there something wroing with my quad ?
Thanks ~
Hello Yang,
Thank you for your interest in the Intel Aero Ready to fly.
Can you tell me what flight program you are using and if you have done a frame reset after updating to the latest software?
I think it would help for you to follow the steps listed on the following link: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup
Check out the "Calibration" part and steps for configuring the Airframe.
Let me know if this works.
Kind regards,
Casandra
Hello Yang,
Kind regards,
Casandra
Hello Yang,
Can you please tell me if the solution provided was helpful or if I can assist with anything else?
Thank you in advance,
Casandra
