Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
Vision Accessory Kit Camera question
DVrta
Dear *,
i see that the Vision Accessory Kit (https://software.intel.com/en-us/aero/vision-kit Vision Accessory Kit | Intel® Aero Platform for UAVs | Intel® Software ) contains two MIPI Camera modules. 8MP RGB Camera (OV8858) and VGA Camera(OV7251).
Does those two cameras connect direct to the Intel Aero Board via MIPI ?
I also saw that the Intel Aero Board (https://software.intel.com/en-us/aero/dev-kit Compute Board for Intel®Aero | Intel® Software ) is running on Linux* 4.4.3-yocto-standard OS powered with Yocto Project* 2.1 (Krogoth).
Does this mean that the Linux is supporting the ISP driver (atomisp) and the MIPI CSI-2 drivers for OV8858 and OV7251?
Best Regards.
Community Manager
Hi zero0d,
Thanks for your interest in the Intel Aero Platform.
I will investigate more to see if the cameras are connected directly through MIPI CSI-2. Also if the default image support ISP driver and the MIPI CSI-2 drivers for OV8858 and OV7251.
I appreciate your patience, have a nice day.
-Jose.
DVrta
Dear Jose,
yes please investigate this mater and please get back to me.
David.
Community Manager
Hi zero0d,
I appreciate your patience. In this thread you will find a guide that explains how to assemble the 8MP RGB Camera (OV8858) and VGA Camera(OV7251) to the Intel Aero. I hope you find this information useful.
Have a nice day.
-Jose
DVrta
Hi Jose,
thank you , this is very helpful information.
But I have another question:
1) When we buy Compute board https://software.intel.com/en-us/aero/dev-kit Compute Board for Intel®Aero | Intel® Software do we get the Linux OS image for the board on some media like CD/USBkey or do we have to download it from somewhere ?
2) When we buy Vision Accessory Kit https://software.intel.com/en-us/aero/vision-kit Vision Accessory Kit | Intel® Aero Platform for UAVs | Intel® Software how we can get the Open source Linux Drivers?
Because it says: " These cameras connect directly to the Intel® Aero Compute Board, and are supported with open source Linux drivers." .
Does this mean it is supported form Intel after buying or are the driver on some media like CD/USBkey or do we have to download it from somewhere?
David.
Community Manager
Hi David,
You will have to download the Linux OS image. In this link (https://github.com/intel-aero/meta-intel-aero/wiki Home · intel-aero/meta-intel-aero Wiki · GitHub ) you can find a tutorial on how to flash the image into the Intel Aero. The drivers should be included in the image, if you encounter any problems regarding the camera please let us know.
I will be waiting for your reply, have a nice day.
-Jose.
DVrta
Hi Jose,
Does the Intel Aero Ready to Fly Drone http://click.intel.com/intel-aero-ready-to-fly-drone.html Intel® Aero Ready to Fly Drone - Intel® Aero Platform Developer Kits comes with mounted Intel Aero Vision Accessory Kit http://click.intel.com/intel-aero-platform-for-uavs-vision-accessory-kit.html Intel® Aero Platform for UAVs Vision Accessory Kit ?
So does the drone also have the two camera MIPI camera (8MP camera and VGA camera) or it only has the RealSense camera(R200)?
We reserved the http://click.intel.com/intel-aero-ready-to-fly-drone.html Intel® Aero Ready to Fly Drone - Intel® Aero Platform Developer Kits , is there a date when it will ship?
David.
Community Manager
Hi David,
In this community we only do technical support. If I have to guess the three cameras should be included, still I would recommend to contact mailto:click.support@intel.com click.support@intel.com. They should also answer when your product will be shipped, if you have any more technical questions, please don't hesitate to contact us.
Have a nice day.
-Jose.
SPate20
Hi Jose,
I am unable to use both the ov7251 & ov8858 cameras. I am copy pasting all the relevant logs from the dmesg related
to both sensors and the ISP.
[3.406965] Ov8858 tal init called[3.409290] OV8858 tal test probe called[3.412364] ov8858 i2c-INT3477:00: gmin: initializing atomisp module subdev data.PMIC ID 1[4.449697] ov8858 i2c-INT3477:00: power-up error -5![4.454106] ov8858 i2c-INT3477:00: ov8858_probe: failed to set config[4.465104] ov8858: probe of i2c-INT3477:00 failed with error -5[4.465173] tal init called[4.473409] tal test probe called[4.510938] ov7251 i2c-INT35AA:00: camera pdata: port: 1 lanes: 4 order: 00000002[4.624394] usb 2-4: new SuperSpeed USB device number 2 using xhci_hcd[5.511063] i2c_designware 808622C1:03: controller timed out[5.516093] ov7251 i2c-INT35AA:00: read from offset 0x300a error -110[5.521967] ov7251 i2c-INT35AA:00: sensor_id_high = 0xffff[5.526730] ov7251 i2c-INT35AA:00: ov7251_detect err s_config.[5.535259] ov7251 i2c-INT35AA:00: sensor power-gating failed[5.551248] tal test probe called[5.584947] ov7251 i2c-INT35AA:01: camera pdata: port: 1 lanes: 4 order: 00000002[6.585227] i2c_designware 808622C1:03: controller timed out[6.590646] ov7251 i2c-INT35AA:01: read from offset 0x300a error -110[6.596520] ov7251 i2c-INT35AA:01: sensor_id_high = 0xffff[6.601301] ov7251 i2c-INT35AA:01: ov7251_detect err s_config.[6.609925] ov7251 i2c-INT35AA:01: sensor power-gating failed[7.098972] atomisp-css2401a0_v21 0000:00:03.0: ISP HPLL frequency base = 1600 MHz[7.261268] atomisp-css2401a0_v21 0000:00:03.0: no camera attached or fail to detect[7.281235] atomisp-css2401a0_v21 0000:00:03.0: hmm_reserved_pool init successfully,hmm_reserved_pool is with 32768 pages.[7.296965] atomisp-css2401a0_v21 0000:00:03.0: Refused to change power state, currently in D3
I have followed the "Dev kit mechanical assembly guide" for connecting the cameras to the board. However the RealSense cameras work with our application that uses librealsense.
Can you pls let me know what I might be doing wrong here?
Subash
Community Manager
Hi Subash,
I'm sorry to hear that your ov7251 and ov8858 cameras are not working. Have you already try the Quick Start Guide and upgrading to the latest software release? Please let me know in order to assist you.
Links:
https://github.com/intel-aero/meta-intel-aero/wiki/Quickstart-Guide Quickstart Guide · intel-aero/meta-intel-aero Wiki · GitHub
https://github.com/intel-aero/meta-intel-aero/wiki/Upgrade-To-Latest-Software-Release Upgrade To Latest Software Release · intel-aero/meta-intel-aero Wiki · GitHub
I will be waiting for your reply, have a nice day!
-Jose
