Community
cancel
Showing results for
Search instead for
Did you mean:
RKura
What is the best application to use to stream live video off the Intel Realsense camera ?
I am trying to stream live video off the Intel Realsense camera. What is the recommended application to do this ?
Are there any code examples in github or anywhere else for it ?
Rohan
Hi RKura, Thank you for your interest in the Intel RealSense cameras. You can use the Intel RealSense Viewer to view the streams. You may find more information and example codes in the link below. https://github.com/IntelRealSense/librealsense Regards, Alexandra
RKura
@Alexandra_Intel​
I will take a look at this. How does the Intel RealSense Viewer compare to Gstreamer and OpenCV ? Which one is better of the 3 and why ?
I am trying to send video from the RealSense camera to my laptop to view. I have used QGC in the past with Gstreamer. Is QGC compatible with Intel RealSense Viewer ?
Hi Rkura, I apologize for providing you the wrong information on my first post. The Intel RealSense Viewer does not work with Intel RealSense R200 embedded on the Aero drone. You can use any application you want, as described in the link below. https://github.com/intel-aero/meta-intel-aero/wiki/06-Cameras-and-Video You may find example codes here: https://github.com/IntelRealSense/librealsense/tree/v1.12.1 Regards, Alexandra
RKura
@Alexandra_Intel​
Thanks. I will take a look and get back to you with further questions.
