- I am finding with my Intel Aero board that the wlan0 interface is not present after I first power-up, which means there is no WiFi.
- To get the wlan0 interface to be recognized, I currently do a soft reboot via the "reboot" command. After the soft reboot, the wlan0 interface is available, but the WiFi access point is not visible.
- To get the WiFi access point to be visible, I need to execute the following three commands, documented on the Wiki:
killall NetworkManager
/etc/rc1.d/K20autostart-hostapd.sh stop
/etc/rc1.d/K20autostart-hostapd.sh start
This is fine when the board is on my desk, but once I mount it in a drone it's going to be very inconvenient. Ideally, the WiFi access point would be available after power-up, without any manual intervention. Will the above issues be resolved so that this is possible? Are patches on the way? (or do I need a firmware update?) I'm using the image that came preprogrammed on the device. Are there other ways to get the wlan0 interface to be recognized without a soft reboot? I also noticed that occasionally the board hangs during a soft reboot at the udev line in the boot sequence. I will give more details next time it happens. I realize the board is very new and there will be issues to iron out, but I would like to ensure that the WiFi issues are on the radar. Once the WiFi is up and running, it is working very nicely as far as I can tell so far, although my testing is only in its early stages.
Hi Dan,
Thank you for your interest in the Intel Aero platform.
I'm not sure what could be causing this issue, and I totally understand your point, when working at home this might not be a big issue, but when working on the field this could be very problematic. Let me investigate this a little bit more, and I'll get back to you soon.
-Pablo
Hello again Dan,
I just want to know something about your issue. You're experiencing this behavior every time you turn on the Aero board or is it only in the first boot after the build? I ask you this because I'm a bit confused by this part of your post and I want to make sure I'm not wrong, "I am finding with my Intel Aero board that the wlan0 interface is not present after I first power-up".
Thank you in advance for your response!
-Pablo
Every time I power-up the Aero board, the wlan0 interface does not show up in the ifconfig list. After a soft reboot via the "reboot" command, wlan0 does show up in the ifconfig output. I'm not reflashing it.
Hi Dan,
Regarding your issue, we can't provide an immediate solution, however, we want to let you know there should be a new version of the firmware available in the next few weeks that will address this problem.
-Pablo
