I think that I have no luck with this drone ... I have the following issue now.
The range of the drone's wifi is about 3 meters range, not enough to do my test outside. Before I was no problem with that.
I am not an expert in wifi but what do you think it is causing that? I was adding some sensors to the drone and during the manipulation I have damaged a little bit the antennas (as you can see on the two photos in attachment).
If you can affirm that this is the cause, can I simply buy another antenna (http://us.yuneec.com/Aero-Drone-WiFi-Antenna-sold-in-pairs http://us.yuneec.com/Aero-Drone-WiFi-Antenna-sold-in-pairs ) and replace them to get it working?
PS: I am not in the following case :
Rudja
- Tags:
- WiFi
The stock antennas do not propagate the signal very well beyond a few meters. It's good for bench top development but not very useful in the field. You can take a look at this instructable below which details how to connect an omnidirectional wifi antenna to help extend your range up to ~50m.
http://www.instructables.com/id/Intel-Aero-Drone-Extending-Wifi-Range/ Intel Aero Drone - Extending Wifi Range: 9 Steps
Hi Rudja,
Thanks for reaching out.
I have gotten the same results as you about the Wi-Fi range when using the drone outdoors. In my opinion, that's the normal behavior and it's not an issue with the drone or the Wi-Fi connectivity. Although, please let me do some research on this to confirm if this should work this way, or if there is something we are missing. I'll let you know once I have additional information.
Have a nice day.
Leonardo R.
Hi Leonardo,
Thanks for your reply.
I have forgotten to put a photo in my last message.
I don't think that is a normal behaviour because even in indoor environment, I got same results. Even a raspberry pi 3, without added antenna, have more range.
Ok, I will wait your confirmation.
Have a nice day!
Rudja
Hi Rudja,
Thanks for the information, I will continue investigating about this, and I will contact you soon.
Have a nice day.
Leonardo R.
I'm experiencing the same problem.
With drone acting as an access point, the wifi distance range is very short when connecting with a laptop.
That can't be normal. What good is a drone that must stay within ten feet?
- Randy
but 3m is way too low. I suspect the antenna is disconnected inside the case.
I'd have to measure to give exact numbers, but I go way farther than that with stock antennas and using an external 5db antenna on host
