Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
Wifi station mode not working
JChin10
I'm a problem with the wifi station mode. The system switch to this mode correctly with this commande: /etc/init.d/autostart-supplicant.sh start
All my wifi ssid are showed and I can configure ssid and psk. All are correctly saved into file /etc/wpa_supplicant.conf, but when I apply the configuration the board does'nt connect to my network.
I'm testing with 2 differents routers, but it's not possible to get ip. When I use the command select_net it's reply OK
(after this post: I'm testing to change channel, but not difference)
I'm also an another problem with wifi, if I reboot the board in command line, the wifi card wlan0 never appears. But if I remove power and restart, the network work again.
Can you help me to resolve it?
This is the content of the /etc/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
network={
ssid="myssid"
psk="mypassword"
key_mgmt=NONE
JChin10
More information, in message showed in screen I have:
wlan0: skip RSN IE - key mgmt mismatch
wlan0: skip WPA IE - key mgmt mismatch
wlan0: allow in non-WPA/WPA2
wlan0: skip - privacy mismatch
But I'm sure the key are correct. My router are configured in mixed mode wpa/wpa2.
Community Manager
Hi JosL,
Thanks for your interest in the Intel® Aero Platform for UAVs.
I'm sorry to hear that your Aero board is not working in AP mode. I have one question before we start looking for a solution to your issue: Did you already updated your BIOS to the latest version (01.00.04)?
I will be waiting for your reply, have a nice day!
-Jose P.
JChin10
I'm just upgrade to 01.00.12, this is resolve the problem with reboot and after reconfigure with wpa_cli I'm the connexion with my router.
Thanks for your help.
Community Manager
Hi JosL,
I'm glad to know that Upgrading the BIOS solve your problem! Please don't hesitate to contact us back if any questions come up.
Have a great day!
-Jose P.
