Community
cancel
Showing results for
Search instead for
Did you mean:
SOpte
New Contributor II
api version mismatch
Jump to solution
I am really tired with this error and failed to figure out what is the problem. I want to run cpp project in Aero kit to do some functions using the realsense camera. I developed the project in another computer (ubuntuOS) and sent the project to the kit. I also sent the librealsense and did all the steps to install it. when I try to ran the project on the kit, I got "api version mismatch" error. The project works perfectly on the other laptop and both have the same librealsense.
I really appreciate any help or suggestion.
P.S: realsense demos work too.
Accepted Solutions
SOpte
New Contributor II
Finally It works!
To suffer from the same problem, check this : http://stackoverflow.com/a/21173918 Linux error while loading shared libraries: cannot open shared object file: No such file or directory - Stack Overflow
SOpte
New Contributor II
Finally It works!
