Community
cancel
Showing results for
Search instead for
Did you mean:
MTsai23
battery charge BIOS problem
I've change the program of battery from BIOS last time.
Now every time I turn on the UAV, it shows that the battery charge is below critical. Even I plug in the wall power supply, it still show the same thing.
How do I fix it?
JesusE_Intel
Hello MTsai23, Could you tell me which changes were made to the bios? Does the board continue to boot after the message or it's just stuck at the splash screen? By the way, is this the same drone and issue as here: https://forums.intel.com/s/question/0D50P00004KOfdz/my-computer-crashed-after-up-set-up-bios Regards, Jesus
