Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
776 Discussions
calibration failure with px4 firmware v1.7.3
RKint
I've loaded the latest release of px4 firmware and qgroundcontrol fails to calibrate.
I get the following errors after attempting to calibrate the radio:
store parameters command failed
settings save error
Error: operation not permitted
I'm using v1.7.3 of the firmware from here: https://github.com/PX4/Firmware https://github.com/PX4/Firmwarehttps://github.com/PX4/Firmware https://github.com/PX4/Firmware
The qgroundcontrol version is: v3.3.0
I've also tried an older version of qgroundcontrol and encountered the same issues.
Any suggestions?
- Randy
UPDATE: This may have been fixed by commit: a25ca0c37d63ea090fda66c199a3b31dd0435d83
Issue: https://github.com/PX4/Firmware/issues/8585
Community Manager
Hello Randy,
Thank you for your interest in the Intel Aero drone.
Have you followed this guide to set up the radio?
https://docs.px4.io/en/config/radio.html
Hope this helps.
Octavian
RKint
This issue is fixed in the latest commit to the master branch.
However, the most recent "stable release" (v1.7.3) _does_ have this bug. I didn't delete this post because I wanted to provide warning/info for others that might encounter this issue.
I'd recommend that support staff try the latest stable release of the firmware so that they are aware of these issues.
