Community
cancel
Showing results for
Search instead for
Did you mean:
AVerm9
does intel aero go into RTL or land mode if it loses wifi connection?
Jump to solution
Hi
Does the intel aero go into RTL or land mode if it loses wifi connection mid-flight while navigating to waypoints?
Where can I find this information and how to change it?
Thanks!
Tags (1)
Community Manager
Hi Ambika_Verma,
Thank you for your interest in the Intel Aero drone.
The wifi will most likely disconnect once you fly the drone.
You can extend the wifi range by replacing the antennas:
https://www.instructables.com/id/Intel-Aero-Drone-Extending-Wifi-Range/
You can also use a telemetry module for the WP flight:
http://ardupilot.org/copter/docs/common-sik-telemetry-radio.html# sik-telemetry-radio
Alexandra
Community Manager
Hi Ambika_Verma,
Alexandra
Community Manager
Hi Ambika_Verma,
Was my answer helpful?
Do you have further questions?
Alexandra
