Community
cancel
Showing results for
Search instead for
Did you mean:
MEppl
drone crashes while recording with D435
Jump to solution
First of all I would like to thank you. With the released USB 3.0 OTG cable the D435 works with the aero compute board.
But now I have a problem with the recording of D435 camera streams. As soon as I start recording with the "record-playback" example and I'm in "Position Hold" flight-modus the drone is not contrallable any more. It immediately tilts to the side and crashes. In "Manual Mode" the drone behaves as normal.
My first assumption was the the CPU usage >200% of the librealsense 2 examples, which is also discussed here: https://github.com/IntelRealSense/librealsense/issues/744 . By following the references and only recording the depth stream I could reduce CPU usage to ~50%. Behaviour is still the same. May it be possible that it has something to do with the high USB3 traffic? It seems like GPS or other important data for flight control gets lost. Looking at the block diagram of the Aero Compute Board I'm wondering what kind of data the Flight-Controller might need from the Compute Board.
Does anyone here has a working system drone + D400 series, or maybe the same issue?
Thank you for your help!
BIOS_VERSION = Aero-01.00.16
OS_VERSION = Ubuntu 16.04.4 LTS"
AIRMAP_VERSION = unknown
FPGA_VERSION = 0xc2
AeroFC firmware version = 1.6.5
Community Manager
Hello MaEp,
Thank you for contacting Intel Customer Support.
Could you send a photo of your set-up?
This might be a power issue. How do you power the D435 camera?
Alexandra
Community Manager
Hello MaEp,
Alexandra
MEppl
Thank you !
Yes seems like it was a power issue. I used an usb-hub between the D435 and the OTG-cable.
Although the camera worked well with the hub removing it and connecting the camera directly to the drone solved the issue.
