Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
drone programming with FPGA
mozel
Hi
I see a document for python. https://github.com/intel-aero/meta-intel-aero/wiki/04-Autonomous-drone-programming-in-Python 04 Autonomous drone programming in Python · intel-aero/meta-intel-aero Wiki · GitHub
Is there a such document for FPGA
Community Manager
Hello Melek,
Thank you for contacting Intel Technical Support.
You can find additional information regarding to FPGA on the following document: https://github.com/intel-aero/meta-intel-aero/wiki/91-(References)-FPGA https://github.com/intel-aero/meta-intel-aero/wiki/91-(References)-FPGA
Hope this helps.
Octavian
Community Manager
Hello Melek,
Thank you for your interest in our Intel products.
We have taken your case into review and will come back to you with more information in the shortest time possible.
Octavian
Community Manager
Hello Melek,
Hope this helps.
Octavian
mozel
Hi Octavian
I am looking for something like "Hello World FGPA" thing. As you suggested I followed up your link and ended up like this. I am not sure about development kit type though.
I set the filter "https://cloud.altera.com/devstore/board/max-10-fpga-development-kit/ MAX 10 FPGA Development Kit"
https://cloud.altera.com/devstore/platform/?acds_version=16.0&family=max-10&board=1 Design Store | Altera Cloud
I found this
https://cloud.altera.com/devstore/platform/16.0.0/Standard/nios-ii-qsys-hello-world-lab/ Nios II + Qsys "Hello World" Lab | Design Store | Altera Cloud
This is lab tutorial
http://www.alterawiki.com/uploads/4/45/Hello_World_Lab_Manual_MAX10.pdf http://www.alterawiki.com/uploads/4/45/Hello_World_Lab_Manual_MAX10.pdf
After running this ok do I get "hello world FGPA" ?
Community Manager
Hello Melek,
We are working on improving the documentation on programming the FPGA, as soon as we have an update we will let you know.
The FPGA is currently use to configure/route the different hardware interfaces available. For example, the aero-rtf.jam will setup the aero compute board to be used in the Aero RTF Drone.
Regarding the example you have linked, we have not tested it yet, but we can test it and share the results with the community.
Octavian
mozel
Hello Octavian
Could you please let the community know when you test and share the results.
Community Manager
Hello Melek,
We haven't tested it yet.
The FPGA is currently used for routing hardware interfaces. You can chose to make modifications and explore the FPGA but you will need to have expertise.
Octavian
