Community
cancel
Showing results for
Search instead for
Did you mean:
AVerm9
how to add ultrasonic sensor to the aero rtf drone
Jump to solution
Hi
for optical flow implementation -
can I add an ultrasonic sensor instead of lidar lite sensor?
Would I need to make any configuration changes to use the ultrasonic sensor for optical flow in addition to the bottom facing camera?
OR
is it that optical flow position hold can only be implemented by using the lidar lite sensor or px4flow module?
Ambika
Tags (1)
Community Manager
Hi Ambika,
Thank you for your interest in the Intel Aero drone.
This sensor has not been tested for optical flow. It depends on the type of interface the sensor uses. You might need to create a new FPGA configuration to add the interface if it is not available with the default FPGA configuration.
You should test it and post the results in the Community.
Alexandra
Community Manager
Hi Ambika,
Alexandra
AVerm9
Hi Alexandra,
Thanks!
Could you direct me to the files where the sensor interface configuration is defined (I believe it is I2C interface for the lidar lite sensor) so that I can make the changes.
Community Manager
Hi Ambika,
You should follow this guide:
https://github.com/intel-aero/meta-intel-aero/wiki/95-(References)-FPGA
Alexandra
