Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
how to factory-reset remote controller? (specktrum dxeA)
HJeon19
I'm currently working on intel drone with QGroundControl app.
but after calibration at qgc's radio setting(spektrum Bind),
intel drone's remote controller not working properly
(does not arm, etc)
Is there some factory-reset sequence or
could you tell me how to re-calibrate remote controller properly?
JesusE_Intel
Hi HJeon19, Thank you for reaching out. Did you flash all the software to the latest version? Take a look at the Initial Setup Document: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup You will need to update the OS, BIOS, FPGA and Flight Controller. Once that is updated, could you provide the output of aero-get-version.py? It is important to do a frame reset via QGC after the update. Take a look at the calibration section: https://github.com/intel-aero/meta-intel-aero/wiki/02-Initial-Setup#calibration Steps to calibrate the spektrum radio are included as well, make sure the stick trims are centered prior to calibrating the remote. Regards, Jesus
JesusE_Intel
