Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
776 Discussions
is macOS supported with the SDK?
JJerr2
is the mac platform supported by the Intel Aero SDK?
Community Manager
Hello jdoob,
Thanks for reaching out!
When you mention the Intel Aero SDK, are you referring to a cross compiling toolchain? Or, what exactly are you referring to?
Let me know.
-Peter.
Community Manager
Hello jdoob,
Do you have any updates about this?
-Peter.
Community Manager
Hi Peter,
I have the same question. i.e Can I grab the sources, and build the software for the Aero compute board on macOS. It would be crying shame if I couldn't, given MacOS's x86-64 native support, and this worked in the past for the Intel Galileo Board.
https://www.linux.com/blog/yocto-project-adds-mac-and-windows-cross-compiler-intels-linux-based-gali... Yocto Project Adds Mac and Windows Cross-Compiler for Intel's Linux-Based Galileo Board | Linux.com | The source for Lin…
Community Manager
Hi irieblue,
So, you are indeed referring to cross compiling toolchain, right? If so, I believe this would follow the same behavior as in Galileo (as you mentioned). If that was the case (which I believe it is), it should be compatible with OSX. Nevertheless, there are no official documentation about this, and you might have to set it up yourself by following Yocto's documentation.
The reason why I believe this should be compatible with OSX is because Yocto usually is and since you have to use their tools to create the toolchain, I see no reason why this time it should be different.
So, my best suggestion at this point is that you follow Yocto's Mega Manual ( http://www.yoctoproject.org/docs/2.1/mega-manual/mega-manual.html) and let us know how it goes.
-Peter.
