Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
775 Discussions
neither a launch file in package nor a launch file name
KAldh
im working on the intel aero ready to fly drone, im trying to test the fly mission codes and been following the steps here https://github.com/intel-aero/sample-apps/tree/master/ros sample-apps/ros at master · intel-aero/sample-apps · GitHub however I get the errors in the photos I attached. It seems like a sourcing issue, so Im hoping someone can show me how to fix the problem.
Community Manager
Hello Khalifa,
Thank you for your interest in the Intel Aero drone.
Your issue has been received and is currently under investigation.
We will reply back to you as soon as possible.
Octavian
Community Manager
Hello Khalifaa,
Thank you for your patience.
I would like to suggest, you try recreating the package/workspace, copy the old files into the package/workspace and afterwards try rebuilding the package/workspace.
Could you try this out and let us know if it works?
Casandra
Community Manager
Hello Khalifaa,
Can you please tell me if the solution provided was helpful or if I can assist with anything else?
Thank you in advance,
Casandra
