Intel® Aero Platform For UAVs
Peer-to-peer support only
This is a peer-to-peer only forum. This forum is not monitored by Intel.
774 Discussions
spidev patch does not compile
pcroc
I tried to add the spidev support for the intel aero by applying the patch 0039-Add-support-for-the-aero-spi-devices.patch
here is the result of the compilation after applying the patch
root@anemos-CherryTrail:~/linux-yocto-4.4.76-aero# make -j 4
HOSTCC scripts/kconfig/conf.o
HOSTLD scripts/kconfig/conf
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
CHK include/generated/timeconst.h
CHK include/generated/bounds.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
GZIP kernel/config_data.gz
CHK kernel/config_data.h
UPD kernel/config_data.h
CC kernel/configs.o
LD kernel/built-in.o
LD drivers/misc/aero-spidev/built-in.o
CC [M] drivers/misc/aero-spidev/spi_imu.o
drivers/misc/aero-spidev/spi_imu.c:26:0: warning: "pr_fmt" redefined
# define pr_fmt(fmt) "spidev-imu: " fmt
In file included from include/linux/kernel.h:13:0,
from include/linux/list.h:8,
from include/linux/kobject.h:20,
from include/linux/device.h:17,
from include/linux/platform_device.h:14,
from drivers/misc/aero-spidev/spi_imu.c:18:
include/linux/printk.h:238:0: note: this is the location of the previous definition
# define pr_fmt(fmt) fmt
CC [M] drivers/misc/aero-spidev/spi_fpga.o
In file included from include/linux/printk.h:6:0,
from include/linux/kernel.h:13,
from drivers/misc/aero-spidev/spi_fpga.c:17:
drivers/misc/aero-spidev/spi_fpga.c: In function 'fpga_spidev_init':
include/linux/kern_levels.h:4:18: warning: format '%d' expects argument of type 'int', but argument 2 has type 'struct spi_master *' [-Wformat=]
# define KERN_SOH "\001" /* ASCII Start Of Header */
include/linux/kern_levels.h:10:18: note: in expansion of macro 'KERN_SOH'
# define KERN_ERR KERN_SOH "3" /* error conditions */
include/linux/printk.h:254:9: note: in expansion of macro 'KERN_ERR'
printk(KERN_ERR pr_fmt(fmt), # __VA_ARGS__)
drivers/misc/aero-spidev/spi_fpga.c:45:9: note: in expansion of macro 'pr_err'
pr_err("SPI master driver not found...return value %d\n", master);
CC drivers/spi/spi-pxa2xx.o
drivers/spi/spi-pxa2xx.c:1514:12: error: redefinition of 'pxa2xx_spi_fw_translate_cs'
static int pxa2xx_spi_fw_translate_cs(struct spi_master *master, unsigned cs)
drivers/spi/spi-pxa2xx.c:1491:12: note: previous definition of 'pxa2xx_spi_fw_translate_cs' was here
drivers/spi/spi-pxa2xx.c:1491:12: warning: 'pxa2xx_spi_fw_translate_cs' defined but not used [-Wunused-function]
scripts/Makefile.build:258 : la recette pour la cible " drivers/spi/spi-pxa2xx.o " a échouée
make[2]: *** [drivers/spi/spi-pxa2xx.o] Erreur 1
scripts/Makefile.build:403 : la recette pour la cible " drivers/spi " a échouée
make[1]: *** [drivers/spi] Erreur 2
make[1]: *** Attente des tâches non terminées....
Makefile:964 : la recette pour la cible " drivers " a échouée
make: *** [drivers] Erreur 2
Community Manager
Hi anemos,
Thank you for your interest in the Intel Aero Platform. Can you please provide additional details of why you need to apply the spidev patch? The patch should already be included in the latest release.
The latest software release can be found here:
https://downloadcenter.intel.com/download/27399/Intel-Aero-Platform-for-UAVs-Installation-Files?v=t
Jesus
pcroc
Hello, I was able to compile this patch finally by modifying the source code by hand.
No, it was maybe included in the latest software release, but was not present in your latest kernel source release.
Community Manager
Interesting, thank you for providing the feedback. I am glad you were able to compile the patch.
Jesus
