Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
ssh Connection of drone to the laptop
Jump to solution
I am trying to establish the ssh connection with my laptop to the drone, so that I can communicate with the drone using my laptop.
My drone is connected to the intel aero hotspot and my lapyop alos is connected to the aero's wifi.
When I try to do establish the connection, it asks for the password if I write '1234567890' it does not accept it.
So can you provide some help regarding this issue.
Thanks and Regards
Accepted Solutions
Highlighted
Hi UGoya, Thank you for your interest in the Intel Aero drone. In order to establish a ssh connection, you would have to disable the hotspot by running the command nmcli c down hotspot and make sure that both the drone and laptop are connected to same WiFi network. You may find more information here: https://github.com/intel-aero/meta-intel-aero/wiki/08-Aero-Network-and-System-Administration#network... Regards, Alexandra
Highlighted
Highlighted
Hi Alexandra
Thanks for the response.
I have successfully established a ssh connection.
Thanks for the support.
Utkarsh
